Thought I would chuck this up here in case people wanted to see photos of the process :)
Vehicle: 2001 Nissan R34 GTR V Spec II
Package: Paint Correction
Condition: Unfortunately just because someone is a “professional” doesn't always mean they are good at what they do. Take this R34 GTR for example that the unlucky owner had to take to numerous different spray painters to get the job done to an acceptable standard and this is what he unfortunately was left with. While holograms are cool on trading cards, they are not cool on your paint. This is where we stepped in to correct the shoddy work done by someone else.
The vehicle was covered in major swirl marks throughout the paintwork and had bad water etching on numerous panels. The bonnet had the most holograms throughout followed by the whole drivers side of the vehicle. Holograms are caused during machine polishing when either not done with correct technique, using dirty pads, using poor quality product or a mixture of all three.
Process: The vehicle was foam decontaminated to remove loose dust and dirt followed by a two bucket hand wash. To remove any overspray, the whole vehicle was clayed and then finally dried. All rubbers, plastics and badges were taped up to avoid getting damaged or while polishing residue on them during the paint correction stage. Using a paint depth gauge the panels were measured and it was found that the roof had a scary amount of paint left. Extra care had to be taken on the roof and heavy compounding was avoided in this area.
The vehicle was compounded using Menzerna FG500 on a rotary polisher followed by polishing with PF2500 using a DA polisher. Finally the paintwork was “jeweled” using SF4000 and an extremely soft Menzerna pad on a medium speed backing off pressure during the final pass. This was done to extract extra lustre from the paint.
Following paint correction the vehicle was covered in Duragloss’ bonding agent and Duragloss’ wet look sealant. The bonding agent is a fairly unique product from Duragloss as it is applied to the paintwork but not removed. The second product goes directly on top of the first and once dried they are removed together acting similar to a Part A/Part B epoxy. This gives the polymer sealant much longer durability.
The results were spectacular with a complete change in the way the vehicle looked. Extreme amounts of gloss and depth were achieved with an extremely wet mirror finish!
Time Taken: Approx 20 hours
All the photos are on the website or Facebook page if you want to see more. www.facebook.com/ATD.AttentionToDetail
Thanks for looking :)
Phil
  • Like 1
What do you mean Ben? On the 50/50 photos? I thought it was quite obvious.
Sorry dude , left off the smiley face.
It is heaps obvious and completely amazing!
Massive improvement.
Ah ok got ya Ben haha.
Yes the roof was extremely thin. Obviously been polished a few times in its life. I dare say it has under 15 micron of clear coat left so I didn't dare remove to much even though a few deep water marks still remained. Better to have a few water marks that you need to squint to look at then to have clear coat failure lol.
Forget Canberra. I only want you to come to Mackay :P
If you ever feel like a working holiday, I'd be more than happy to pay for you to come make my car look that amazing
As always Phil, Amazing job.
I'll see what I can do. I'd love to get my paint finished. Its a bit of a mix at the moment. Have old original paint on half the panels, The roof was resprayed and I'm not real happy with how they blended it, and I have pretty much brand new paint on the front end. It could use with a good detail and some paint protection :)
I might ask around and see what I can work out.
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
