Hey, Hey its on again, Drift practice and come and try day on the 1st of August.
This day will be set-up so that those who would like to learn and spend time on the track with LIKE minded people can do so without pressure from other drivers. Splitting the entrants into either 2 or 3 groups, experienced, intermediate and beginner. Let me know what YOU think. Any intrest in a car setup night or two before hand?
The cost will be $70 per entered car (whole day) there will be between 30-40 cars allowed for the event.
PLEASE SUPPORT THIS EVENT AS FUTURE EVENTS AT MALLALA HINGE ON THE SUCCESS AND SUPPORT YOU GIVE THIS ONE.
1ST AUGUST MALLALA
entry forms will be posted up soon
EMAIL QUESTIONS OR SUGGESTIONS TO [email protected]
https://www.sau.com.au/forums/topic/45432-drift-mallala-1st-august/
  • Replies 44
1ST AUGUST MALLALA
Dont want to sound negative here Trent, but werent the 4500 spectators Mallala got through their gates - bigger crowd than the Konica cars - enough to show the organisers the potential of the sport?
Surely a properly run event like the PSi day has to have more clout with Mallala than a come and try event?
Has anybody got a spare couple of rims I can borrow?:P  Might have to start bugging used tyre mart too.
Bl4cK32, if she aint run in, borrow Dean's car!
What size rims are you after Steve? Depending on how busy I am, I have a set of 17's that I am going to paint up, but if I haven't started it by then you are more than welcome to have a lend of them - 2x 17x7 and 2x 17x9
Chris
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
    • It makes you wonder, all these people starting to make a billet replacement head, I wonder if any have thought about trying to adapt tech from newer engines into them. You're already at the full design stage to make a billet head... Why not really spice it up and had some more modern tech into the mix too...
