Just want some advice from people who have used these clutches first hand http://www.kudosmotorsports.com/catalog/exedy-exedy-heavy-duty-cushion-button-clutch-kit-nsk7056hdcb-nissan-skyline-hr31-jdm-r32-gts4-gtst-r33-gts25t-p-14.html and would like to know if they are a good clutch or is there something better i can get for around that amount that is daily-able and can handle all the clutch kicks. Thanks!
https://www.sau.com.au/forums/topic/454333-clutch-for-daily-drivendrift-days/
My NPC carbotic also felt just like stock when I was using 32 gts-t clutch master cylinder. Using 33 clutch master and it is slightly heavier but nothing ridiculous. Still very light for what it is able to handle.
NPC 10inch carbotic button clutch stock pedal feel cost around $700 and will handle 400kw best option by far.
Ouch. I paid $1200 iirc for the same clutch but pull type. Shows how much more expensive they are. This was 2 years ago though.
Shit thats a big diff, where did you buy from? I bought about 8months ago.
Direct from NPC. Shows the price difference between Push and Pull. And that was just the clutch/pressure plate assembly. No flywheel.
Yeah ive seen it with other clutches aswell pull version is always more but this is almost double haha crazy.
Got my carbotic with npc flywheel for $600, love the for sale section, bought the pressure plate new as well...
Pedal feel is good, but the grab is nowhere near stock, especially in reverse... It does love to be dumped though
  • 3 weeks later...
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
