haha i used to like gate noise but then i didnt like fines and re-cert (in nz). If I was in burnout comp and had pipes i could un-plum i agree they sound the biz.
but they have no biz on the road. kids think they are cool.
Lol so an RB or 2J sound like shit or camrys without gate? You must be deaf from all that gayte brah?
As Joey said whats wrong with some nice induction noise & a nice rumbling RB noise?
Maybe you're driving the wrong car ;)
Just lacks that finishing touch of aggression in the car to me. Im driving the right cars lol got my rb turbo and my charged ls3 both nice and loud ?
I have to agree with Mico.. External gates make the car sound shit.. The gate is generally so loud that the turbo spool can't even be heard.
I have both my gates plumbed in and the car makes plenty of power and response, is legal and still sounds like a screaming jet
This solve an issues. I'm confident with my choice regarding the plumb back then !
Every muffler robs 100 whp? I find that VERY hard to believe.
me too.. all my muffler are bought.. but i could always substitute one muffler for a straight resonator, since they are smaller, they might restrict less.
None the less, I'M pretty sure my 3.5/4 inch exhaust could cope with a 650-700whp build especially considering a 3 inch line has been seen a lot of time on 600whp build.
What the mech said about "every muffler costing 100HP of flow" doesn't necessarily mean that it will cost you an actual 100HP. It's an overstatement anyway, so ignore the actual number. But the real meaning is that every muffler added takes 100HP off the max capacity of that system. If you're only using 75% of that capacity anyway, then that muffler will only cost around 75 HP.
  • Like 1
2) As for the oil issue. I decided to go with the tomei pump ( and sell both my N1 used pump and used oem with reimax gearset).
I know the greddy extended pan is not a popular choice here, but i personally know 4 local GTRer who drove with that and no drama happened both in term of oil issue and cracked pan so I will go with the easiest solution. ( i.e: Racefab is approx. 1200-1400 and will be tight to meet my ETA , while the greddy is easy to get and cost 400$) and racefab is also 15mm
3) i went with 1000cc bosh ev14. better be safe. price is difference is quite minimal
4) I will plumb back.. exhaust setup seems okay.
5) Now for the ATTKD / Hi-octane / Autech air/oil separator, they will come up at 300$ and most people tell me i should still run this setup in parallel with a catch-can.. makes me wonder if these can are really worth the 300$ or they do very little.. ( keep in mind, i also have mine's cam baffle)
thought on this !? :)
Edited by cobrAA
I found the catch can alone ( in conjunction with the sump to catch can lines) ok ...I like the idea of an air/oil separator to catch any fumes that get past the catch can before they are fed into the turbo intake but with a properly baffled catch can you "should" be ok.
Regarding the trust sump... RIPS offer a pre-weld kit.. looks like a better option lol
Yes I do a pre-welded kit that you then weld into your sump, they are nzd695 + shipping.
The sit only about 5-10mm lower than stock (doesn’t go below the x-member) but are a lot wider, they have a surge tank and baffles and hold an extra 1.5 to 2 liters. We use them on all our high power wet sump motors.
Tomei pump-
Oil restricter-
Mines baffes and vented 2-4lt catch can
Walbro 460 in tank pump
BCPR7ES- .8 plugs
Plumb back the waste gate... properly
Exhaust is a hard one... bigger you go, louder it is... quieter, more restrictive. 400+ rwkw- 3.5" minimum or 4" with as many good quality mufflers as you can get under it.
Simples...
  • Like 1
Tomei pump-
Oil restricter-
BCPR7ES- .8 plugs
Simples...
To add to that.
Have a breather from your sump to catch can to get rid of excess crank case pressure
4inch exhaust inc the cat, 3.5 after wards I would suggest
To add to that.
yup this is what i wanted to do but like my mechanic pointed out, the efr 83/74 exit at 3.5inch so he said theres no real advantage beside pricier and bulkier to fit a 4 inch downpipe. Then I told him it was for the plumb back and said well... yeah okay we could but i would stay 3.5inch all the way still.
I'M opening it, shot peening and cryo the gearset /input shaft + new synchro set that will be touched as well.
In all honesty, I hope it hangs together for you... but once you start staring up the skirt of 400+rwkw, 3rd gear just packs up and goes home.
I look at GTR's as either as responsive as possible low mount 380rwkw or balls out torque and lag top mount 450+rwkw with a gearbox and front lsd...
Cheers
J.
a 400+rwkw turbo on an rb26.... to my definition, it will be laggy (-5's are bad enough). If set up correctly, it will be one of the better lag v's power turbo's... but laggy compared to a well set up low mount (N1, GTSS, -7, t517z) rb26.
Being easy on the gearbox will go along way to helping it survive, but 3rd gear just strips.... it just does.
I had a brand new replacement gearbox in my GTR, low mount's and the 3 or 4th pass down the strip 3rd gear just disappeared. I was even granny shifting (not double clutching like I should).
Again, I hope it all goes well for you. I hope you get your oiling system sorted out.... but start saving for a couple of gearboxes or a gear set.
    • Well, the car is back, all straight and shiny, for how long for is anyone's guess  After picking it up we went for a bit of a drive, Jebus I really enjoy driving this little thing, hopefully the weather let's us go for a nice long cruise this weekend as it will be out of my hands for at least a few days next week when it heads back into Mania on Monday It's weird, whilst I do always enjoy going for a drive, the NC makes me feel like a kid who has just got his first car, and they just want to drive wherever and whenever they can I really need to look into the MX5 Club of NSW
    • wow that is some seriously JDM original credibility there!
    • Selling hks rb25 cast manifold and waste gate.   Never going to use as don't have Rb powered car  Unknown condition of waste gate diaphragm  $900 Pick up only Ipswich Qld
    • Yeah it will surely need a diode to stop the headlight turning on when the indicator does, I'm pretty sure all it would need is a wire from the headlight parker wire (via a diode) to the indicator 12v. Assuming you also convert to LED that is....I'm not sure if the standard wiring will take the load of the extra indicator globes if they are incandescent
    • Post up or shoot me a list of anything you need (other than R34 specific), I've been meaning to move on some spares
