Hi All,
I have read up about similar issues on the forum but still unable to locate my problem.
My stag has a miss at idle and in high rev range but not too bad though the middle I have changed coils and the car comes good for a day then back to missing again. Plugs are only 1000km old gaped to .8, new AFM. I have pulled the plugs out and the drivers side look really good but the passenger side look a bit black compared to the drivers side.
Please help, any ideas?
https://www.sau.com.au/forums/topic/454380-m35-stagea-missing/
ok checks hoses, all look and feel ok.
I started unplugging coild packs 1 by 1, passenger side no change when removing drivers side as soon as i unplug 1 the car runs ruff.
Its only running on the 3 drivers side cylinders??? WTF??
anyone heard of this?
Also, check for error codes. Could be Cam pos sensor on left bank if there are no related mods like ecu piggyback, coil packs, etc.
Which plugs did you put in?
I used NGK Iridiums LFR6AIX-11 but gapped down to .8
I have checked for codes but there is nothing there...
It feels like a timing issue to me...I have swapped out the rear sensor on the left bank.
Good chance you damaged the plugs, they are too fine and brittle to gap down if you have done so.
I use LFR7aix, but a stock M35 should be fine running the hotter 6's. The plugs I use though are already gapped at .8mm, and I run mine up to 40psi without a problem on the original 14 year old coils.
Any sensor issues will be quickly picked up by the ecu and a fault light will be displayed. What the ecu doesn't know is if you plugged the coilpacks in the wrong order for example. It's very easy to mix the front plugs up, try swapping them around.
Cheers Scotty I will give it a go
Ok swapped out the plugs to the old ones (LFR6aix-p) no change, the front 2 coil plugs can't get swapped on mine as there isn't enough length in the plug wire..... ?
On the passenger side? The rear two can be mixed up then yeh? It's the coils where the plugs sit back to back you need to worry about, I have seen them mixed up many times, sometimes it's even my fault. :P
  • Like 2
checked again Scotty, but I was able to get any mixed up with my Stagea as the length of each plug will only go to 1 spot. I did change 3 of the spark plugs back to the old one and it seemed to make a bit of difference to the mid and top end, i will change out the other 3 this weekend coming as I don't have the car with me. I'm also replacing the PCV valve too see if that make any difference to the idle.
I have been also thinking of do an injector clean, good idea??? I'm thinking it cant hurt to do it....
If anyone else has any ideas, they would be greatly appreciated.
I can send you a refurbished set of injectors if you like, but that probably won't be the issue. You can most definitely mix up two of the plugs on each side, the ones that face each other where the plugs are nearly touching. Try it out before anything else...
I swapped over the plugs but it only just reached....you can see in the pic the front and middle are different lengths, the drivers side could get mixed up.
I'm really starting to lean towards injectors
Scotty if can pm me about the injectors you have, that would be great, unless any other ideas
ok yep, i swapped them around, no good.
i pulled the injectors, all good nice and clean, flowing nice.
i was having a listen to the exhaust and i think there might be something loose there and when the turbo comes on i can hear a different noise i havent heard before, im also using more fuel then usual, im going to have a look into the exhaust this weekend coming. could be a blocked exhaust all along.....
i love solving problems but i hope i can solve this soon cause its really giving me the shits!!! lol
    • A lot of the trim pieces on the E39 are super brittle and just dissolve when you try to get them off. It looks like a previous owner has used what can only be described as an industrial construction foam adhesive to glue down a tiny piece of trim.  Unfortunately this part of the tailgate is starting to rust because of how much shit is in here. This is stopping the water draining and there's a big build-up of dirt that is just staying wet. How can I remove this? Would a flap disc get rid of this?  I think this car spent a lot of time inland. There's so much light coloured, fine dirt and dust everywhere.  Sorry for the pic. I've cleaned this all up now so I'll get another pic of it clean today.
    • Surely, just about any shop that has done a Skyline (or Supra, or RX-7, or EVO, or WRX) will have done E85. But perhaps you need to specify what type of car, what type of engine, what ECU, you propose to be using.
    • Try an oil additive. There's a couple of options for "easier shifting". These are essentially a similar idea to what Redline put into their Shockproof gear oils. I had a 2nd hand R33 (in fact, as of right now, it is still in the car) that simply would not engage any gear with the engine running, with normal gear oil in it. We dropped that and replaced it with Shockproof lightweight, and suddenly the gear lever did what it was supposed to. At a cost, of course, of the then ongoing damage to internals done by running Shockproof. But the synchros were already totally uninterested in life, so there was no loss.
    • It always ends with the car burning down.
    • I see what you posted, but how could a warning light be going on and off if there is no sender for it?  The only other explanation is that the wire that used to go to the sender from the warning light is earthing somehow in the loom or at the connector, or that you have connected the warning light wire to something (maybe the temp sender?).
