Hi All,
I have read up about similar issues on the forum but still unable to locate my problem.
My stag has a miss at idle and in high rev range but not too bad though the middle I have changed coils and the car comes good for a day then back to missing again. Plugs are only 1000km old gaped to .8, new AFM. I have pulled the plugs out and the drivers side look really good but the passenger side look a bit black compared to the drivers side.
Please help, any ideas?
https://www.sau.com.au/forums/topic/454380-m35-stagea-missing/
ok checks hoses, all look and feel ok.
I started unplugging coild packs 1 by 1, passenger side no change when removing drivers side as soon as i unplug 1 the car runs ruff.
Its only running on the 3 drivers side cylinders??? WTF??
anyone heard of this?
Also, check for error codes. Could be Cam pos sensor on left bank if there are no related mods like ecu piggyback, coil packs, etc.
Which plugs did you put in?
I used NGK Iridiums LFR6AIX-11 but gapped down to .8
I have checked for codes but there is nothing there...
It feels like a timing issue to me...I have swapped out the rear sensor on the left bank.
Good chance you damaged the plugs, they are too fine and brittle to gap down if you have done so.
I use LFR7aix, but a stock M35 should be fine running the hotter 6's. The plugs I use though are already gapped at .8mm, and I run mine up to 40psi without a problem on the original 14 year old coils.
Any sensor issues will be quickly picked up by the ecu and a fault light will be displayed. What the ecu doesn't know is if you plugged the coilpacks in the wrong order for example. It's very easy to mix the front plugs up, try swapping them around.
Cheers Scotty I will give it a go
Ok swapped out the plugs to the old ones (LFR6aix-p) no change, the front 2 coil plugs can't get swapped on mine as there isn't enough length in the plug wire..... ?
On the passenger side? The rear two can be mixed up then yeh? It's the coils where the plugs sit back to back you need to worry about, I have seen them mixed up many times, sometimes it's even my fault. :P
  • Like 2
checked again Scotty, but I was able to get any mixed up with my Stagea as the length of each plug will only go to 1 spot. I did change 3 of the spark plugs back to the old one and it seemed to make a bit of difference to the mid and top end, i will change out the other 3 this weekend coming as I don't have the car with me. I'm also replacing the PCV valve too see if that make any difference to the idle.
I have been also thinking of do an injector clean, good idea??? I'm thinking it cant hurt to do it....
If anyone else has any ideas, they would be greatly appreciated.
I can send you a refurbished set of injectors if you like, but that probably won't be the issue. You can most definitely mix up two of the plugs on each side, the ones that face each other where the plugs are nearly touching. Try it out before anything else...
I swapped over the plugs but it only just reached....you can see in the pic the front and middle are different lengths, the drivers side could get mixed up.
I'm really starting to lean towards injectors
Scotty if can pm me about the injectors you have, that would be great, unless any other ideas
ok yep, i swapped them around, no good.
i pulled the injectors, all good nice and clean, flowing nice.
i was having a listen to the exhaust and i think there might be something loose there and when the turbo comes on i can hear a different noise i havent heard before, im also using more fuel then usual, im going to have a look into the exhaust this weekend coming. could be a blocked exhaust all along.....
i love solving problems but i hope i can solve this soon cause its really giving me the shits!!! lol
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
    • No I got mine from a friend that had fabricated one … but I had to fit it to my setup which was a hks turbo setup. His was a Garrett -7. So one of my turbos was not a flange for one side … then I had a leak in the welds I had to find a weld shut … in the end the setup was decent priced but I spent a lot to get it fitted. A couple companies I checked would make it but you’re talking 7-9k aud with titanium. No joke mine was 6-7k even second hand after I had to fit it in Hong Kong … labour is expensive here.
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
    • Got just the wing painted and fitted up to the existing boot. Big visual change and about time after having a GTR wing sitting in the shed since 2018 Headed up to Mallala with a quick obligatory stop in at Boliver OTR Oil control mods seems to have worked. I checked the catch can after session 1 and there was a dribble of water/e85 with barely any oil in it. After session 2 and 3 there was almost nothing and I stopped checking after that. so either great success or catastrophic failure/block of the external breather The GTR wing made a noticeable difference in the 160-185km/h sweepers. It was a very hot day for the cars at over 33C but the previously done cooling upgrade/ducting/water sprayers meant I never saw over 60C intake, 105C water and 100C oil and temps would drop back down very quickly once I shut it down. AD09's are a decent tyre but certainly and expectedly a step down when compared the the CR-S/AR-1 I have had on the car for years of track days. The handling characteristics of my car which I often describe using the Tony Hawks Pro Skater balance mechanic where either side of the center is understeer/oversteer was much more pronounced with no "green/safe" zone in the middle. However, imo it steers well/easily during oversteer largely thanks to the custom ACOSTAL front end. Enjoy a loose lap POV with my mate giggling away as a passenger.   Group photo for Peer Pressure Racing made it back home and gave it a wash Overall a great success compared to my previous two track days where i cooked the Starlets motor and blew up the new diff in the R32
