hey mate,
i am having this same problem, also using shit tons of fuel(roughly 200km to a tank). my car needs the o2 sensor replaced. i have ordered it from nissan and will let you know how it goes fixing it.
my car blows fuel smoke on full throttle. the idle likes to wander from 800 to 500. and when it goes to 500 it sounds like it's missing.
my stag was never good on fuel from the day i bought it. and only threw the o2 sensor code, 6 months after i bought it.
will keep you informed
Where are you djtee? There is something seriously wrong with your car for it to be going through that much fuel, I doubt the o2 sensor will be the only issue, as the rich running will have ruined it. Could be worth sticking the Consult 3 on it.
im in sydney mate, i purchased one of your afm's about 3 months ago.
i've had it plugged into a diagnostic computer, and all it came up with was the o2 secsor, it wasn't giving any signal at all...
today i checked for airleaks/broken airlines to the fuel regulator, but it was all sealed nicely.
Hi guys,
well i ripped the cat out out the dump pipe and fuel economy has returned to normal, still have a bit of a rough idle but the power down has returned and driving great again, im not sure what i would have to do to correct the idle but i am happy that the car is back to normal driving if not better!
only thing i can think of is replacing the o2 sensor. might try that soon.
thanks heaps Scotty!
I hope this cant help other people, and i would recommend getting rid of that constrictive front dump/cat!
  • 2 years later...
I am having a similar issue, but it's only missing under load.  When it starts making boost, it seems that it starts to have a miss.
The interesting thing is I ended up getting a fault code a couple of times indicating a coil issue before this missing under load started, which I have cleared, reset, dropped the power from the battery and everything goes back to normal.  The coil issue would only happen after leaving the car for a while, starting and then it would run rough (like one cylinder was down), then all of a sudden come good, but the engine check light would come up.
  • 1 year later...
I'm still having this issue.  I've checked all the plugs, replaced all the coils (thinking it was a bad coil and I had done 150K on them...)
For some reason it's an intermittent fault.  It happens when the car is idling (cold), feels like it's missing, but it's not regular.  Then under full throttle (so boost) it will miss regularly.  No fault codes, no engine light.
Does anyone have any thoughts?
I've had a bit of trouble with old and hardened manifold vac/boost hoses blowing off under boost. Last one was difficult to spot since the fuel rail (fuel pressure regulator) end had come off. I now know what to look for when the idle goes a bit wonky... but it shouldnt happen now that the bad hoses have been replaced.
You could start the motor and remove the non-manifold end of each hose one at a time. Block the end with your thumb to verify there's vacuum and that the idle changes. If you have a vacuum gauge check what the manifold has at idle.
Heya Stabby man.  Yes, your thought process is along mine aswell. I thought it was a vacuum leak somewhere initially, and found a hose that I thought was causing the problem that was going to the OEM ECU boost sensor, but after replacing said tube, the issue is still there.
Now working with my local trusted mechanic, I have had plugs replaced , the issue still exists.  I am currently using 'Hanshin' coils from Ebay (supposedly the same as OEM...) and currently suspect these may be causing the issue.
Does anyone have a cheap way of buying OEM Nissan coils.  Currently Kudos Motorsport have them for $136.40 (NIS-22448-AL61C)
The frustrating thing with this is it's intermittent. The car will idle fine, but then all of a sudden miss and stumble.  The only reliable thing is when it's under load it will miss.  Thinking this is coils currently.
Mine would idle ok when cold, and when hot it would idle for a short time ok, then get rough. With RB motors i've heard of circumstances where the coilpacks get marginal when they're hot. Havent heard of that with VQ coils but it could be a thing.
Oh - the other issue i noticed when there was a vac leak was that both fuel trims would max out (one at +25% and the other at +10%). info  https://www.sau.com.au/forums/topic/280322-m35-obd2-or-is-it/page/4/#comments
    • Do the following first and get back to us. - Clean and verify your IACV - Verify for vacuum leaks/post MAF leaks. (Pressure test is the best and cheapest way) - Do you have a BOV with stock ecu/MAF? If so, remove it.
    • Hey all, The skyline I have is stalling when the engine is at normal operating temp.  When starting it while it is cold, it'll run just fine.  I have replaced the battery (bad cell), I have replaced the fuel pump, fuel filter and clean the MAF sensor.  Any other suggestions?
    • Thanks for all the information on this.  I tried ordering the parts from Amayama website and all 3 Solenoids are discontinued and not available.  Does anyone have any other websites to suggest that I could find the parts?   Separate issue-- I will start a new thread, but basically the vehicle is stalling when warmed up.
    • It's unfortunate what Tomei USA has done to Tomei's name in general. I'm very weary of ordering parts from them now. I only order direct from a Japanse source (e.g Nengun). At least their logos are different, so you end up knowing what you have.
    • Update Issues 5 (plus #4) - 10 After making a claim about issue #4's missing part, DeAgostini Japan sent a whole new issue #4 and it arrived about 2 weeks after that. That was back in early March. It took another 4 weeks to receive issues 5 - 13 though. This update is for issues 5 - 10. Ove the 5 issues the front left suspension and most of the engine have been completed. The quality of the castings and fit of the parts is quite good, it seems better than DeAgostini's BNR34 Skyline GT-R from the Fast & Furious 2 movie, which (to me anyway) doesn't seem to have as tight tolerances or quite as accurate castings.  Each issue has a lot of info about the 1989 - 1993 Skyline range and other Nissan models from that era, but the focus is on the BNR32 Skyline GT-R Nismo and the various racing it did in Japan, Europe (Spa 24hrs) and of course Australia. I've included some text translated with Google Lens in some photos and will add to them if there's anything worth including.
