1989 R32 gts-t 4 door sedan. Midnight purple in colour (resprayed in japan). Traveled 144,8xxkms. Original owner since import in 2004.
VIN: 6U9000HCR320342235
no RWC
Modifications:
  • Imported as an RB25 conversion
  • Converted to straight Liquid injected LPG (not duel fuel). System made by JTG and installed my smithies LPG. 60L tank. Travels about 400kms with normal driving and 300km with a heavy foot. System cost about $5000 for install pre govt rebate.
  • Power FC tuned by craig at Revzone. Making 270kw and 15psi. Safe conservative tune.
  • Z32 afm
  • HKS 3037 pro s turbo
  • Custom turbo back exhaust
  • Front mount intercooler retaining factory engine bay piping.
  • Oil cooler and filter relocation kit
  • large alloy radiator
  • gizzmo boost controller
  • catch can
  • Koni shocks and lowered springs
  • R32 gtr front brakes
  • braided brake lines
  • Shimmed Diff
  • Alloy subframe bushes
  • Hicas lock bar. All hicas has been removed from the car. Now using an RB25 power steering pump.
  • A/c removed
  • RAYS ceremo sport rims. semi slick tyres. Dunlop direzza 03G 235/45 r17 front, Hankook Ventus TD 255/40 r17 rear. approx 50% tread.
  • Exedy heavy duty clutch
The car has been serviced ever 5000kms. Mechanically sound. Heaps of power and torque and cheap to run.
Bad points: Paint is rough. No prep work done when the front bar was resprayed in Japan so paint has started falling off over the years (a respray of front bar can be arranged). Interior is average for age. steering wheel has wear, rear seats are different cloth to front, 1 A pillar and 1 C pillar cover is missing. No stereo.
This car would suit someone looking for a 'Sleeper' with a difference (LPG), who wants something mechanically sound, and isn't so concerned about cosmetics. This is the only LPG R32 i know of, and one of only a few LPG cars making this much power!
$9000
contact via PM. Located in Chirnside Park VIC
Edited by R324DR
  • 1 month later...
  • 9 months later...
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
    • Strength. And on the early RB26, full engagement of the pump drive.
