I will be leaving to go O/S for 7 months shortly and I am unsure about what to do with my fuel system while I am away and my car is in storage.
I can have my Dad drive it from time to time but it will still sit for a few weeks between drives most likely.
Plan was to drain the E85 and run 98 in it until it runs like shit and then shut it down... I have ID1300 stainless injectors and a Walbro 460 along with Barricade fuel line. Only thing that isn't E85 compliant is my fuel reg.
Interested to hear some ideas...
Thanks in advance for the feeback.
https://www.sau.com.au/forums/topic/454409-e85-fuel-system-storage/
Either option will be alright, even if can give a good drive once a month making sure get oil up to temp you wont have a issue with leaving it sitting with e85 for a few weeks or like you said drain it and try get as much out of injectors as you can and just leave it, I would go for the drive every few weeks option if I had choice.
If its going to be sitting there for weeks on end I'd only be running 98 in it..
Ethenol with f*ck your pumps real quick and clog your injectors with jelly. Seen this first hand.
First thing I did when my engine blew was take my ID2000s out and got them cleaned. They ll stay in a bag until its ready to run
Yeah thats true, but from what ive expereinced in my own my track car has been e85 for 4 years now and most of the time will sit for a month between events not being run and pumps and injectors have not had a problem (044 feed pump, nismo intank lift pump and fiveo injectors) but If sitting longer than a month I will atleast run the car for a few min just to get the e85 running through the pump and injectors to avoid the issues you listed.
Edited by boostn0199
Same thing happens with the cleaning/flow testing solution anyway, and petrol for that matter. I wouldn't be getting them cleaned until you are ready to install them again.
Can I ask what happened to your pump? My car sits for maybe 3 weeks max at a time and there doesn't seem to be any issues but a couple of weeks ago I put the car on the dyno and the pump seemed to be struggling. (Walbro 400 making 300kw on -7s so should be plenty of head room).
I have 2 walbro 400s and a nismo lift, I drained all the ethenol out of the. But didn't flush them
My pumps personally haven't been tested but I'm going to assume that the pumps I have are fecked.. I hope not bit after 18 months I don't hold hope for them
The pumps I have seen fail simply just lose pressure I until the car barely runs
My engine popped with E85 in it. Injectors and pumps sat around for 10 months while I sorted it all out.
One of the feed pumps became quite lazy (AFR and pressure gauges showed this) and my spray pattern was a disaster on the ID 2000's. No amount of cleaning made them usable again.
The only thing I can put it down to is the E85. If that happens on pump fuel then you're fooked either way.
The only 460 I have seen fail, which seized, had been flushed with water. Moisture will be your only issue, so if flushed in petrol or better, kero, and put in a sealed container you shouldn't have any problems.
(edit: Spraying a little wd40 in the inlet may help combat the rust internally too. )
IIRC Trent from checkered tuning (fk knows how to spell it haha) suggested that E85 doesn't lubricate the seals in fuel pumps and injectors or something similar. He always runs some sort of motul additive.
I would have thought 5 years continuous use is enough to dispel those rumors, surely my old 255 Walbro's would have flogged out by now if it was ever going to be an issue... Same goes for the Xspurt 1000's.
Your choice if you want to run an additive, but i would be worried what the additive is doing, not the ethanol.
Just putting it out there mate. Trent said he had been running it for 4-5 years and he's in the business of knowing this sort of stuff. I'm not suggesting that it's required just putting it out there so people can make their own educated choices.
Unfortunately threads like this put fear into people's minds, and really, no-one knows the long term effects on components, so education is not really an option. This is exactly why I only run e85 in both my cars, to dispel the myths.
Leaving any fuel in your tank for long periods will cause problems, petrol, c16 and diesel all have worse issues than anyone generally experiences with old e85, as long as your fuel system is sealed.
  • Like 1
Thanks for the feedback everyone.
I'm thinking at this stage as I run a surge tank, I will hook up an old fuel pump to the feed line with just enough 98 octane to start the engine and so it will only sit with 98 in the feed and return line.
I will get my Dad to drive it at least every 2 weeks with E85 in it then. Should be a good solution in case it does go a month sitting still.
That looks like the issue.
Micko has run E85 in both his cars for years and hasn't had an issue. The problem is when they sit around for months and months on end that problems start to pop up. But sitting around like a shag on a rock they don't like generally.
I run the e85 out of the tank and put 20lt of 98 in to flush the system... my drift car sits for a few months at a time between floggings/
My question is, why do you worry so much about it to flush with petrol? Have you had issues previously, or is it just down to the myths again? Straight Ethanol is stable long term from my experience, not sure about the additives United etc run with e85, but it doesn't turn to jelly in a jerry can or 44gal that's for sure.
Not saying you shouldn't flush it, but surely just replacing the e85 before you start it would suffice? Those with ev14 2000's would need to be more worried than most I guess.
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
