I've noticed recently that when I come onto boost under moderate acceleration I hear a big screech sound which I assumed to be a belt. I've tightened the PS belt 2 times already as after having a look, that one appeared to be the loosest. Now its no longer the loosest, the ac one is, but to be honest, while that one has the most slack, I wouldn't call any of them "loose". This makes me a little confused as to what's making the noise and how serious it is.
Background info - Engine done 128k, belts in good condition, belts and tensioners/pulleys all replaced 28,000kms ago, air con compressor works, but leaks green dye and is original. Water pump and timing belt changed with belts.
Anyone know what's going on?
If the AC is off when you accelerate, but it still screeches, it shouldn't be that as it won't have any load to cause slipping.
Other than that you could try loading up the electrical systyem...
Or take a video of it happening
When this happens, do you see 2-black lines on the road behind you?
Seriously though, sounds like a turbo to manifold gasket.
They can make some crazy noises and mostly only start to play up once boost builds.
ha, I wish. Gaskets never occured to me. Have others had this?
i did a little test this morning. If i accelerate slowly up to high revs, i cant hear the noise. If i accel hard and get on boost, i hear it. This makes me think it could be a gasket as it doesnt appear to revs related but rather boost/acceleration related. Thoughts?
I had screeching on boost, it was my exhaust manifold - I had 4 snapped studs!
The video sounds similar to what I have.
While you're working on your car grease your clutch pedal assembly :P
Can't really hear it from the video, but try taking off the turbo heat shield and see if there's any loose studs or any gaskets blown. It will be fairly noticeable.
Well I spent a few hours ripping the bay apart. I got down to the turbo and manifold. The good was that there was nothing obvious broken or hanging off, which is almost a little bad in that the answer still isn't clear. That said, I did notice that the manifold to turbo gasket wasn't uniform at the edges, and that on both sides there were gaps, suggesting it may be partially disintegrated and boost could be leaking through. As a stop-gap I pushed into the gaps a little high temp liquid gasket to see if I can seal it up a little, just until I work out what I want to do as a proper solution. Also the turbo nut locking tabs had opened out, but I hear they have a tendency to do this over time. I tightened the nuts a little (4th one cant be accessed tho) and put it all back together. Tomorrow I hope to see if there is any change.
  • 1 month later...
For anyone reading this Ive done a fair amount of work to the car and its solved it. Specifically I got a turbo high flow and at the same time replaced pretty much all gaskets, studs, nuts etc from the block to the down pipe and the problem is gone. Not really to chase this problem, but it worked out anyway. Not much help in diagnosing it therefore, but looks like it was something there. possibly the dump to downpipe as I wonder how tight it was done up.
    • Depends how low and tyre size. Should fit with natural camber, skinny tyres and rolled guards.
    • Hi guys, planning to get 18x9 +25 in fronts and 18x10 +25 in rears been reading the whole thread and cant really find anything   Anyone know if these will fit a r34 gtt with no scrubbing or guard work needed?
    • They usually get made by hand as part of any such swap.
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
