Good notes Adam!
Definitely one of the biggest themes of the day was how the driveline is designed with shock absorbing capability, and changing this with stiffer components can lead to damage if the whole system isn't appropriately matched.
Yeah i reckon its something like this below - area under the curve is the same, but peak load/force is much lower with a soft (sprung) clutch. Engineering 101.
  • Like 1
Cheers guys for another great tech arvo.
Thanks to Award, Terry and Trish :)
Learnt some new things and got in some laughs as well.
Thanks Adam for the notes as well!
Will be looking forward to the next one :)
Was a damn shame I missed this, with both sleeping in and my calendar reminder not set properly I got the reminder 10 min's before the event :(
"Solid mounting of diff cradles also increases rigidity in a way that's detrimental (for the gearbox? or drive train more generally?), so make especially sure you use a sprung center clutch if you have a solidly mounted diff cradle."
This is good to know as I've just fitted a diff craddle and will be putting in the g'box brace in soon too, guess with the brass button clutch this is going to destroy my gearbox prematurely. :) JOY hahaa
oh, and lol.. not sure how many people found out in the day, but it turns out Terry and Trish live 2 doors down from me. It didn't click until we went outside for the ridiculously big spread they put on and i saw their car.
all in all, i think i learnt more from this tech session than any of the others.... thanks to all involved in organizing and putting the day on.
shift sedately and you will be fine, so no time attack shifts for you just yet!
I'm sure you'll find it's not so much how you shift the box as it is how you reengage the clutch that destroys boxes, this will apply to both going up AND down gears, should be done just like a motorbike, find friction point then release clutch not find floor then release clutch
  • Like 1
The other bit I got out of the day (more informative than anything) is that the only major difference between the series 3 BCNR33 boxes and other 32/33 boxes is that the syncros are "pad-type" rather than held in by circlips and also have a stronger (bigger) 5th gear synchro making them the design of choice if you have the option.
He also recommended that cleaning the gearbox can be done by running ATF in it for a while. Could be useful for those wanting to move away from smurfsblood which is nearly impossible to remove.
It was also interesting that Terry mentioned there is not a major difference in the various LSDs out there however for big power/time attack cars he did seem to recommend the Cusco up front. Seems he can also modify the standard ones making it potentially a cheaper option.
brass button clutch what friction point ?? HAHA
Yeah i think we was saying that like gearboxes, which are pretty much all the same in how they work, the factory, Nismo, Cusco etc LSDs are also pretty much the same. He can setup the rear to be tighter, however, since the after market ones are larger/beefier they will last longer.
I destroyed 5 brass buttons in 2 years due to the torque and everyone of them had a friction point
The distance between off and on was very very small though
no worries I have no torque HAHA
    • My hold point for future mods is that I want a OEM detachable hard top first, but, finding one is a pain, MX5 Mania are looking for one for me, but, as hens teeth are more common, finding one in Australia is proving problematic  I can get a OEM one from overseas, hell, you can still get new ones in 'Merica, but, shipping is a absolute killer and I cannot justify the cost, or the risk of it being damaged during transport As for the aftermarket hardtops, whilst they do the job of being a hard top, and are fine for a track car, they don't seal well (read: leak like a sieve in the rain), and you need a plastic/poly rear window, plus they are a bolt in option only and not made to be easily removed I liked how the hard top on my NB could be fitted, and removed, by myself, in less than 5 minutes I know it sounds bad, but I'm waiting for someone to write off a car with one so I can swoop in on their pain, it will go to a good home though, so my guilt of this is tempered
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
    • Ye, in terms of bolting up the "Conversion" from a GT to a GTT is effectively "Use GTT parts for everything" Except the subframe itself, because you won't want a HICAS/4WS subframe. Remember your ABS system will be different too, thanks to GT being the S15 3 sensor system, instead of the R34 4 sensor system for wheel speed. I do not know how people get this to work given R34 diffs do not have a provision for an ABS sensor (they are on the tone wheels of the axles). I assume***** people use S15 gear/R34NA forever when they realize this - Or they convert it to a rear diff/axles that are R33 style which I presume has the singular speed sensor on the diff itself, but then you have to wire it all in and...and... and...
    • Foreshadowing was never so easy.
