Good notes Adam!
Definitely one of the biggest themes of the day was how the driveline is designed with shock absorbing capability, and changing this with stiffer components can lead to damage if the whole system isn't appropriately matched.
Yeah i reckon its something like this below - area under the curve is the same, but peak load/force is much lower with a soft (sprung) clutch. Engineering 101.
  • Like 1
Cheers guys for another great tech arvo.
Thanks to Award, Terry and Trish :)
Learnt some new things and got in some laughs as well.
Thanks Adam for the notes as well!
Will be looking forward to the next one :)
Was a damn shame I missed this, with both sleeping in and my calendar reminder not set properly I got the reminder 10 min's before the event :(
"Solid mounting of diff cradles also increases rigidity in a way that's detrimental (for the gearbox? or drive train more generally?), so make especially sure you use a sprung center clutch if you have a solidly mounted diff cradle."
This is good to know as I've just fitted a diff craddle and will be putting in the g'box brace in soon too, guess with the brass button clutch this is going to destroy my gearbox prematurely. :) JOY hahaa
oh, and lol.. not sure how many people found out in the day, but it turns out Terry and Trish live 2 doors down from me. It didn't click until we went outside for the ridiculously big spread they put on and i saw their car.
all in all, i think i learnt more from this tech session than any of the others.... thanks to all involved in organizing and putting the day on.
shift sedately and you will be fine, so no time attack shifts for you just yet!
I'm sure you'll find it's not so much how you shift the box as it is how you reengage the clutch that destroys boxes, this will apply to both going up AND down gears, should be done just like a motorbike, find friction point then release clutch not find floor then release clutch
  • Like 1
The other bit I got out of the day (more informative than anything) is that the only major difference between the series 3 BCNR33 boxes and other 32/33 boxes is that the syncros are "pad-type" rather than held in by circlips and also have a stronger (bigger) 5th gear synchro making them the design of choice if you have the option.
He also recommended that cleaning the gearbox can be done by running ATF in it for a while. Could be useful for those wanting to move away from smurfsblood which is nearly impossible to remove.
It was also interesting that Terry mentioned there is not a major difference in the various LSDs out there however for big power/time attack cars he did seem to recommend the Cusco up front. Seems he can also modify the standard ones making it potentially a cheaper option.
brass button clutch what friction point ?? HAHA
Yeah i think we was saying that like gearboxes, which are pretty much all the same in how they work, the factory, Nismo, Cusco etc LSDs are also pretty much the same. He can setup the rear to be tighter, however, since the after market ones are larger/beefier they will last longer.
I destroyed 5 brass buttons in 2 years due to the torque and everyone of them had a friction point
The distance between off and on was very very small though
no worries I have no torque HAHA
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
