If you look at the arias AP331154A RB25 pistons with a 12.5cc dome, you get 9.1:1
Note Arias call these an 8.1:1 comp piston, but check the comp height, these will likely sit 0.005" further down the bore
Just trying to sort out this deck height problem, I have two spare standard rb25 blocks here at home both measuring 188.6mm deck height and both have .020" (0.5mm) piston out of the top of the block. So I'm assuming the rb25det has a negative deck height standard. So my current block I'm using is .029" (0.7mm) out the top with the cp Pistons I have meaning only 0.2mm) has been decked from the block. Can anyone confirm this?
Anyone confirm how much negative deck height on a stock block
I wouldnt be too concerned about how far the piston sticks out of the block if its a slight amount.
I be very worried about the piston to head clearance, you need to allow for stretch and rock at change of direction when at song so they dont physically meet.
If your dech was taller (not decked) you would run a thinner head gasket to keep the same head to piston clearance (that you were looking for).
Do not try to radically increase compression by running the head gasket so thin that the pistons and head will meet.
Whatever the dome is on the piston, will not effect compression much far from what they were designed to produce by the manufaturer by your blocks deck height, either way you will need to keep the piston and head appart a certain amount.
If your chasing a compression increase and already have a piston to head clearance of around 1mm (40 thou) with your calculations, start looking for a larger domed piston, going any thinner on the head gasket could end in disaster.
Your engine builder should be aware of all this.....speak to them as they will know the piston to head clearance.
If your piston sticks out 1mm, you can get the decks machined down while leaving the dome alone to increase compression, another way to bump up what your after because you can run a thinner head gasket while maintaining the correct quench between the pistons and head.
Edited by GTRPSI
Thanks for the reply, not concerned with having high compression, I'd be happy with anything between 9:1 and 9.5:1, more concerned with things being too close more than Anything. The Pistons are .029" out the top was just wanting to know where they sit on a standard block. Cheers
Do your calculations then based on a 1.75mm head gasket (or as your builder advises) if chasing a 40 thou quench, how far the pistons protrude above the deck top should not be an issue unless the top ring land position is questionable.
Mine are 0.6mm out of the deck on my RB26/30.....means little as long as there is enough room for assembly stretch and piston rock at high RPM.
But not too much space, you dont want secondard detonation pockets. ;)
You can provide less space if Red line RPM's are kept under check.
    • In a few years from now, you'll regret that. It'll eat away at you, knowing the truth of the ugly hiding beneath the beautiful exterior... 😛
    • I don't think the G2 profile is particularly dangerous for the engine per se, more just are you actually ok with the turbo lag trade-offs? If the answer is yes then go for it. I personally don't think I'd be ok with it because I spend so much time at lower RPMs and I really enjoy the feeling of being able to stay in 5th gear on the highway and just roll into the throttle to get boost. Or staying in 3rd gear on "gentle canyon cruises" without feeling the turbo lag too badly. The 525 pump should be able to run flat out on factory lines but I would bet the pressure drop from pump to regulator is quite impressive. I don't know how much it would be exactly but I've seen figures like 30 psi thrown around.
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
