DIY Painting Front Grill
Hi all
I painted my front grill matte black and it looks quite nice on white skylines.
If you want to try it out, I hope this DIY guide helps you out!
post-133804-0-71664200-1425601887_thumb.jpg post-133804-0-04508400-1425602022_thumb.jpg
Tools needed:
12-15cm flat head screw driver
Some newspaper or cardboard
Dish wash liquid
Sponge
Paint (I used 1/3 or less can of plasti dip)
Step 1: Removing the front grill
You will need to remove all the pins holding the grill using a flat head screw driver.
To remove the side lock pins (circled in red in the picture), insert the flat head screw driver and turn the lock pin inside clockwise to release it. This video is very helpful too. You do not need to remove the pin circled in green. Please refer to pictures for further details.
Step 2: Remove Nissan badge and wash grill
Even if you want to paint the badge, I still recommend removing it so you can paint the curvy parts better. Using dish washing soap and a sponge, wash the grill. If you have a bath tub, it is every better. I used warm water. Note that I put the plasti dip can inside the warm water too. This is to melt the rubber inside or make it softer so when you spray it, it is much finer and the finish is better. Dry it using a microfiber cloth. If you want, you can use hair dryer to dry hard to reach corners.
post-133804-0-01638600-1425601921_thumb.jpg post-133804-0-83993400-1425601938_thumb.jpg post-133804-0-36029400-1425601951_thumb.jpg
Step 3: Painting
Put the grill on top of some newspapers or a cardboard like I did so you do not mess your floor (I over sprayed a bit lol). When you paint, spray around 20cm from the grill and start and finish each spray out of the grill. I applied 4 times in an interval of 25 minutes. Let it dry overnight and put the badge back on.
post-133804-0-23194700-1425601968_thumb.jpg post-133804-0-69033200-1425601980_thumb.jpg
Step 4: Put the grill back
Seems straight forward but I struggled 3 minutes to figure out how to put it back.
You will need to take the lock pin out from the hole and attach to the grill first. Then you can slide the grill back and put back all the lock pins and you are done! :banana:
Next project is restoring headlights!
  • Like 1
https://www.sau.com.au/forums/topic/454474-diy-painting-front-grill/
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
    • 300hp (225kw) is barely outside the standard turbo's range with a bit of extra boost in it (200ish). If you are going to change the turbo you should aim for 250-300kw (330-400hp) to make the expense worthwhile
    • A couple of things, firstly omg that turbo is expensive! $3,000 USD for dinosaur technology is robbery. You could buy a G series turbo and have a good amount of change instead.  If you want a good budget option, have a look here - https://hypergearturbos.com/product/rb25dethighflow/ If you are keen to spend more, have look at the modern turbos, Garrett G series, Borgwarner EFR, etc. Have a look at the RB25 dyno results thread for inspiration.  If you upgrade your turbo to something that will support the 300hp you want and only "probably" have Haltech ECU, your car will only "probably" run. Actually, no it won't run. You are going to need the ECU and injectors at the time you do the turbo upgrade.  No thoughts on "this much boost" as you didn't say how much boost that actually is. Having said that, plenty of unopened RB25's making even more power then what you are chasing.
