DIY Painting Front Grill
Hi all
I painted my front grill matte black and it looks quite nice on white skylines.
If you want to try it out, I hope this DIY guide helps you out!
post-133804-0-71664200-1425601887_thumb.jpg post-133804-0-04508400-1425602022_thumb.jpg
Tools needed:
12-15cm flat head screw driver
Some newspaper or cardboard
Dish wash liquid
Sponge
Paint (I used 1/3 or less can of plasti dip)
Step 1: Removing the front grill
You will need to remove all the pins holding the grill using a flat head screw driver.
To remove the side lock pins (circled in red in the picture), insert the flat head screw driver and turn the lock pin inside clockwise to release it. This video is very helpful too. You do not need to remove the pin circled in green. Please refer to pictures for further details.
Step 2: Remove Nissan badge and wash grill
Even if you want to paint the badge, I still recommend removing it so you can paint the curvy parts better. Using dish washing soap and a sponge, wash the grill. If you have a bath tub, it is every better. I used warm water. Note that I put the plasti dip can inside the warm water too. This is to melt the rubber inside or make it softer so when you spray it, it is much finer and the finish is better. Dry it using a microfiber cloth. If you want, you can use hair dryer to dry hard to reach corners.
post-133804-0-01638600-1425601921_thumb.jpg post-133804-0-83993400-1425601938_thumb.jpg post-133804-0-36029400-1425601951_thumb.jpg
Step 3: Painting
Put the grill on top of some newspapers or a cardboard like I did so you do not mess your floor (I over sprayed a bit lol). When you paint, spray around 20cm from the grill and start and finish each spray out of the grill. I applied 4 times in an interval of 25 minutes. Let it dry overnight and put the badge back on.
post-133804-0-23194700-1425601968_thumb.jpg post-133804-0-69033200-1425601980_thumb.jpg
Step 4: Put the grill back
Seems straight forward but I struggled 3 minutes to figure out how to put it back.
You will need to take the lock pin out from the hole and attach to the grill first. Then you can slide the grill back and put back all the lock pins and you are done! :banana:
Next project is restoring headlights!
  • Like 1
https://www.sau.com.au/forums/topic/454474-diy-painting-front-grill/
