Something a bit left field, thought I would share the massive task we are undertaking in setting up and building a Factory GT3 program for AC Automotive on their 2014 MK VI Cobra. Not everyday you get to peek behind the curtains of a factory program
As part of their new owners plans motorsport and gt racing in particualr has come up as a way of bringing some attention back to the fact that there are still genuine AC cars being built not everything is a kit car.
As an aero designer / developer this car has been a bigger challenge than getting the Bentley Brick to be conpetitive, due to the strict rules around what can and can't be modified or changed, however 1 small advantage we have is that this car is tiny compared to the others so what isn't ideal for aero isn't impacting as much.
Chassis:
Tube frame production car chassis, is unchanged other than the addition of the FIA rollcage and mounting opoints for the transaxel gearbox.
Most GT3 cars need to go on a large shredding diet to bet down to fighting weight, Given our Cobra is Sub 1 tonne fully fitted out with aircon / radio and leather we have the opportunity to devleop the car with ther weight where it is needed to keep low and central
Engine:
Given a "production" rle set we are running GM V8's as per the street car. Our V8 will be a sister engine to the Corvette C7R that has mad a lot of success over the last few years and performed well in the endurance races
Gearbox:
I'm happy to get an Aussie product in with the Albins ST6 found from teh back of a V8 supercar into the read of the cobra. Mated with a OBR control system for paddle shift
Happy to try and answer any questions and update as the build / development goes on
  • Like 2
https://www.sau.com.au/forums/topic/454477-ac-cobra-gt3/
I am guessing the GTSR would make a 997 GT2RS look boring!
Specs aren't 1/2 bad either:
995Kg, 780HP and 1050NM
Here is our base 430hp one taking on a ZR1
Unfortunately I cancelled my trip last week heading over to Europe to the AC factory on friday :verymad: , as had an change in my business here in Australia.
https://www.sau.com.au/forums/topic/454477-ac-cobra-gt3/#findComment-7494158
  • 1 month later...
  • 4 weeks later...
  • 1 month later...
Need more updates!@!
Sorry Mate, been flat out this year
Due to a huge amount of Interest in a GTE spec from Europe / Asia and America the first car being built ( Started ) is being done to 2016 GTE Regulations and prep for LeMans underway
https://www.sau.com.au/forums/topic/454477-ac-cobra-gt3/#findComment-7568235
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
