After a bit of farting around it seems the sensor is dodgy.. And thanks also to the efforts of Andrew from Kudos Motorsport I'm certain the wreckers I got the sensor from supplied an r33 gtst sensor and mistaken it for a GTR sensor. Have a new sensor on order and should hopefully fix the problem
We have checked all wires right up to the cluster and it all seems in order. Tapping the speed sensor while its in gear the reading seems accurate, and best of all constant.. So something seems dodgy inside the sensor itself. Bit of a f**k around which could have been avoided if i had the right sensor but such is life
Thanks everyone for the help. Will inform you if the problem is resolved when sensor arrives
  • 1 year later...
Any luck solving the problem?
ive got a very similar issue. Nismo white dials. Speedo dial just randomly decides when it wants to work or not.
Dials were converted from kmh to mph in 2005. Can't see any obvious wiring on the back to change the signal other than the aerial switch which seems to be wired into the loom going onto the back of the speedo connector.
Was it the sensor on the gearbox? I might try a new one of them
On ‎07‎/‎03‎/‎2015 at 2:12 AM, 89CAL said:
O.K I have had issues in this area before with my reverse lights. They worked intermittently (funnily enough) and I bought a new reverse switch but discovered the problem before I put the new switch in. Reverse lights would flicker on and off etc
I've circled the speed sensor plug (top of drawing circled in black) and the plug I had problems with (was just dirty, cleaned it up, checked connections were good)
And in the next one it shows the same thing but in a wiring schematic, just so its easier to work out which wire is which. Its pretty easy looking at the plug to work out which wires are which. Just hold the plug and look at it in relation to which side of the plug on the drawing. If you need a hand I can help anyway. Ive marked around the plugs and put dots where the wires for the speed sensor are
Just found this as well, shows the speed sensor drawing as well
yes 89 Cal!
That top diagram is brilliant.  I just disconnected a connector that you circled at the bottom next to the relay housing this morning before work - it was absolutely full of white gunk.  solvent sprayed it a load and my clocks worked perfectly on the way to work. I'll give the plug a really good clean up later on.
I took the clocks out last night and got the speedo off, then resoldered the four connections between the motor and the circuit board by just dabbing the soldering iron onto it.  I don't reckon this is the smoking gun though - I think it is the connector that you circled.
If anyone has a speedo that's really intermittent then check the connector between the screen wash fluid and the box full of relays (front left of engine bay).  Give it a thorough clean.
Cheers
onto the next problem... high idle and damp headlights!
Edited by CraigoGTR33
typo
    • Hey guys I’m chasing a Rb20det complete or bare block need a good running engine as mine has low comp
    • You're making my point for me. 95 is not "premium". It is a "slightly higher octane" version of the basic 91 product. The premium product that they want people to buy (for all the venal corporate reasons of making more profit, and all the possibly specious reasons of it being a "better" fuel with nicer additive packages) is the 98 octane stuff. 95 is the classic middle child. No-one wants it. No-one cares about it. It is just there, occupying a space in the product hierarchy.
    • 98 and 95 have to meet the same national fuel standards beside the actual RON.  91 has lower standards (which are quite poor really), so 95 is certainly not 91 with some octane booster. It would be an easier argument to claim 98 is just 95 with some octane boosters. Also RON doesn't specify 'quality' in any sense, only the octane number.  Anything different retailers decide or not decide to add to their 95 or 98 is arbitrary and not defined by the RON figure.
    • Anyone know alternatives to powerplus tungsten? Can't find an alternative online.
    • 95 is just a scam outright. 98 is the real "premium" with all the best detergents and other additive packages, and at least historically, used to be more dense also. 95 is just 91 bargain basement shit with a little extra octane rating. Of course, there's 91 and there's 91 also. I always (back in the 90s early 2000s) refused to put fuel in from supermarket related fuel chains on the basis that it was nasty half arsed shit imported from Indonesia. Nowadays, I suspect that there is little difference between the nasty half-arsed shit brought in by the "bargain" chains and the nasty half-arsed shit brought in by the big brands, given that most of it is coming from the same SEAsian refineries. Anyway - if there's still anything to that logic, then it would apply to 95 also. 98 is only made in decent refineries and, as I said, is usually the "premium" fuel, both in terms of octane rating and "use this because it's good for your engine because it's got the unicorn jizz in it!".
