hey i just got pulled over again and this time they must have heard my bov so they called a traffic cop to assist cos he was supposed to know whats, i played the "i dont know anything card" but when he said my boost controller was a bov as well as a boost controller i told him he didnt know sh1t so after he threatened to get his pen and paper out and start to write down everything wrong with it shut up, anyways i dont wana remove the bov cos i would have to weld up the hole in the fmic piping so i want turn it to a plumb back but i need the plumb back adaptor for a turbosmart type3 ss, if anyone has one please let me know or if anyone has any ideas how to make it plumb back another way that would be good, i got the stock parts but it would be a pain in the ass to do the bov
https://www.sau.com.au/forums/topic/454499-bov/
For sale section or buy from a turbosmart dealer. There are going to be no 'other' ways to make it plumb-back that are going to be easier then buying the right adapter and hooking it up. The adapter will cost stuff all (probably $30, if I could get a Greddy one for that price I'm sure turbosmart are close)
https://www.sau.com.au/forums/topic/454499-bov/#findComment-7492305
Rule number 1 when pulled over, act resectfully to the police, act dumb (dont know much about cars), and hope they spot something basic on the outside to write the ticket for so they dont open the hood, thats the sort of defect that can be easy to clear as in most cases being too low of having tyres sticking out of the guards simply means presenting the car to Vic Roads (or whoever is the equivalent in your state) for a inspection to clear just what got written up and nothing else.
My sons been done for having tyres out of the guards twice and (too) lowered once, all 3 times put stock parts on, lady comes out and looks, sees stock height or wheels, defect cleared, aftermarket parts bolted back on the moment it got home, Hwy patrol are constanly looking at it now, we are starting to think they have gven up as im sure the previous defects show up yet the car is back as it was and all they do is stare now.
Think of being pulled over as a bit of a attitude test.
You need to plumb it back, your not allowed to vent to atmosphere, its a simple as that now.
https://www.sau.com.au/forums/topic/454499-bov/#findComment-7492380
yeah thanks for the advice, that is very good advice. Yeah i will plumb back the bov if i can get the adapter plate or i will have to put the stick one back on and as for the dual stage boost controller im a lil bummed out about having to remove that, the dumb ass only knew to look at that cos its bright blue and looks obviously aftermarket, i seen that i can put the stock one on and ground the wire to keep it in high boost but thats only 7psi and i want the whole 12 that it can take safely, so i was thinking about going a 12psi actuator that can simply replace the stock one and then i can paint it black and put a nissan sticker on it just in case so it doesnt stand out. Does anyone have one for sale or know where i can get one cheap, and are they pretty much generic fit or do i need one specific for the stock r33 turbo?
https://www.sau.com.au/forums/topic/454499-bov/#findComment-7492746
Why not buy a discreet boost tee, some black boost line and hide the boost tee where you cant see it? If you think you only got caught because it stood out, then hide it somewhere better.
I think the R32 GTSt actuators run about 10psi. Honestly though, without an aftermarket ECU I wouldnt bother running any more then 7psi. I ran 10psi in mine through the stock ECU and it hit R&R badly and just wasn't real nice. Even when I got boost to the right point where it would run till redline, it was still not great. Did the high boost mod to the standard boost solenoid and running around 7psi again it seemed so much nicer.
My advice, take it or leave it. Save some money, buy an ECU with in-built boost control (Link/Vipec etc, even the PowerFC can do it with the optional boost kit) and get it tuned. You will be amazed how much better it runs, and if the tuner is good you will get better fuel economy and so on
https://www.sau.com.au/forums/topic/454499-bov/#findComment-7492879
yeah i am so i would have to remove aftermarket one on the fmic and have the hole welded up and then i can put the stock one back on the cross over pipe and plumb it to the intake, unless i can track down the plumb back adapter for the aftermarket one and then i can just simply plumb that one to the intake. Its a pain in the ass lol
https://www.sau.com.au/forums/topic/454499-bov/#findComment-7493527
the original is a metal pipe that goes straight into the rubber air intake hose on the turbo and the other end just uses a bit of rubber hose to join the metal pipe to the stock bov, thankfully i still have all of the stock parts
https://www.sau.com.au/forums/topic/454499-bov/#findComment-7494905
finding right size hose proving to be a little difficult but may be able to modify original pipe to shorten distance to front mount intercooler piping where new bov is located & 35mm hose is not real flexable lol
https://www.sau.com.au/forums/topic/454499-bov/#findComment-7495329
if the hose from the plenium to the bov was blocked would the bov stay closed permanently, or would pressure in the ic pipe force it open sometimes?
i thought about fitting the stick bov back on in the stock location and leaving my aftermarket one where it is and then finding some kind of valve so i can run the plenium vac hose to both bov and have the valve set so i can direct the vac line to goto whichever bov i want at the flick of a switch, as long as the bov that isnt turned on doesnt open at all.
I hope i have described this right
https://www.sau.com.au/forums/topic/454499-bov/#findComment-7502178
That's a bad plan.
The pressure from the plenum is required to keep the bov closed while on boost
https://www.sau.com.au/forums/topic/454499-bov/#findComment-7502191
Seriously. Just run the stock one, or buy an aftermarket plumback one and plumb it up. If you really want to change the noise (this is the only reason I changed mine, because I don't like the stock BOV noise, not I wanted a hektik sound) then you can still change it with a plumback, and get none of the drawbacks of an atmo.
It's not worth the trouble of defects and getting harrased all the time.
  • Like 1
https://www.sau.com.au/forums/topic/454499-bov/#findComment-7502245
    • in my list I had the R33 GTR as the best Skyline. Infact I had all GTR's (33>34=32), the NSX, the GTO, the 300ZX, the 180SX, the S15 better than the FD RX7. I had the MR2 and the A80 as 'just' better. I also think the DC5R Integra looks better but this is an 01 onwards car. I also think the FC>FD. It's almost like aesthetics are individual! The elements @GTSBoy likes about the FD and dislikes about the 180 are inverse in my eyes. I hate the rear end of the FD and it's weird tail lights that are bulbous and remind me of early hyundai excels. They are not striking, nor iconic, nor retro cool. The GTO has supercar proportions. I maintain these look much better in person (like the NSX) especially with nice wheels and suspension which is mandatory for all cars pretty much. Some (or all) of these you have to see in person to appreciate. You can't write a car off until you see one in the flesh IMO. Like most people we probably just like/dislike cars which represent certain eras of design or design styles in general. I also think the 60's Jag E type looks HORRIBLE, literally disgusting, and the 2000GT is nothing to write home about. FWIW I don't think the Dodge Viper Gen1's have aged very well either. You can probably see where I rate bubbly coupes like the FD. I know we're straying now but the C4 and C5 absolutely murder the Viper in the looks department as time goes on, for my eyes. Wouldn't surprise me if people who love the FD, also love the MX5, Dodge Viper, Jag E Type, etc etc.
    • I used to hate R31s, and any of the other Nissans that led up to it, and any of the Toyotas with similar styling, because of the boxiness. They were, and remain, childish, simplistic, and generally awful. I appreciate R31s a lot more now, but only the JDM 2 door. The ADM 4 door (and any other 4 door, even if they are unique compared to our local one) can eat a bowl of dicks. The Aussie R31 is also forever tarnished by their association with stereotypical bong clutching Aussie R31 owners of the 90s and early 2000s. I think the Nissans of the 70s (other than 120Y/180B/200B) are far superior looking to the 80s cars. The 240K era Skylines are boss. The same is broadly true of Toyotas. Hondas don't ever register in my thinking, from any era. Mitsus are all horrid shitboxen in any era, and so also don't register. Subarus are always awful, ditto. Daihatsus and Suzukis also don't generally register. They are all invisible. I think the SW20 MR2 looks fiddly. The 3000GT/GTO is like that but way worse. Too many silly plastic barnacles and fiddly gimmicks ruined what could have been a really nice base shape. Kinda-sorta looks like a big heavy ST165 Celica coupe (and I'm not sure if that's a good thing or a bad thing). I think the 180SX is dreadfully bland. It's not bad looking. But it has no excitement to it at all. It's just a liftback coupe thing with no interest in its lines, and bad graphical elements (ie wide expanses of taillight plastic on the rear garnish). The S13 Silvia is a little better - getting closer to R32 shapes. But still....bland. S14? Nope. Don't love it. S15...a little better. Probably a lot better, actually. Benefits from not being like a shrunk in the wash R34 (where the S13 was a shrunk in the wash R32 and the S14 looked like a Pulsar or something else from the stable on Nissan mid 90s horrors). The Z32 was hot as f**k when it came out but hasn't aged as well as the A80. Keep in mind that I think the R33 is the most disgusting looking thing - and out of all the previous cars mentioned is objectively closest to my precious R32. It's just....real bad, almost everywhere you look. And that is down to the majority of what was designed in the 90s being shit. All Nissans from that era look like shit. Most other brands ditto. In that context, the FD absolutely stands out as being by far the best looking car, for reasons already discussed. Going behind the aesthetics, the suspension alone makes it better than almost any other car.
    • If they just called it the "Mazda Tiffany", it would have been spot on.
    • Yup but for me its the HR ! Cut my teeth on the old holden 6s in the day ! And here's me thinking in the day it was also the 300ZX and the Mitsubishi GT3000 ! All, as well had good lines, but always seemed to need finishing off, style wise.
    • A 180SX has a much better look than a FD. The roofline is far superior being a fastback. It's popups look better. In a world where we all subconsciously add a little bit of low, and wheels of our preference, it's just more handsome than the FD is. The FD just looks 'bubbly' in comparison. It can come down to preference, sure. But "The FD is the BEST looking (on appearances alone) 90's JDM car without question?" Nah. Plenty of questions lol. I could think of 8 cars I think look fundamentally better, and probably a handful of ones that look about on par with a FD. (like say a SW20 MR2) I feel people like/overrate the FD because of it's mythicality/rarity, its rotary and it's unpredictable nature. It probably drives great, you can stuff a ton of tyre under there, has a unique sound, light as hell. I feel that people reading this thinking "YOU CANT RATE A 180 ABOVE A FD BECAUSE A 180 IS A CHEAP DRIFT BUCKET" prove the point about bias as to what the car represents, moreso than how it actually looks.. I feel the 80's boxy/squared off look is becoming better looking due to time, and 90's melted soap bar aesthetics have not aged well. (yet?) And this thread is purely about looks :p
