No dyno this week I've got a hold of an old fella that's going to work his magic on my carbs and I've got to get a fuel reg and get my dizzy re graphed again it needs abit more advance down low for the bigger camshaft
  • Like 1
Looks to be running pretty rich , and in answer to the earlier question, run a decent duct up from the side of the Rad and drill holes all reound the Filter body helped a lot as did inverting the lid, this however depends on whether it was one of the big sumbitch oil bath aircleaner's .
Yeah it's running pretty rich it's spitting fuel out the exhaust, I'm getting the reg tonight and playing with the fuel pressure, I've been told to run about 2-2.5 psi, apparently dellortos don't like a lot of fuel pressure.
3-5 PSI was normal for the average red motor mechanical pump, Fuel pressure shouldn't be an issue as the float in the Carb should be regulating properly, I'd look at the possibility that the float needed seats are not sealing 100 % as this can manifest it'self in a number of ways or there might be interference in the Choke bypass circuit that is loading her up with fuel at idle.
The audio above sounded pretty clean so it is likely a low speed circuit in the Carbs that needs tuning and balancing.
Just had another listen to the Idle video and I concur the suspicion you have the low speed circuit loading it up and the timing at idle seems off too (based on the sound)
Edited by MozzMann
  • 3 weeks later...
  • 3 months later...
post-134876-14423701237979_thumb.jpg new manifold for the old girl, I ended up blowing it up, so instead of rebuilding it I'm going to do up a 202 to group nc specs because I want to turn the Orange lc in a group nc car car hopefully try and get around the 280 to 300hp mark
  • Like 1
  • 1 month later...
Thought I'd put these pics up for the old boys on here to reminisce on the old day, few years ago I pick up a old roller sports sedan lc/LJ torana, just because it looked awesome, well last night I found some pics of it back in it hey day racing, this is reaching back in 1980post-134876-14466011098864_thumb.jpgpost-134876-14466011243268_thumb.jpgpost-134876-14466011598339_thumb.jpgpost-134876-14466011695511_thumb.jpgpost-134876-14466011806746_thumb.jpg.
This is the livery the car still has now, I don't have a full pic of how it sits now but this is the pics I have of it
post-134876-14466013236671_thumb.jpgpost-134876-14466013432032_thumb.jpgpost-134876-14466013929915_thumb.jpg
[emoji106]
  • Like 2
I haven't pulled it out of the car yet, but I'm pretty sure it's because the sump has no baffles in it , saving up for a ASR sump, , also doing a cash job on a vk and getting an accumulator setup off a xu1 for my motor. Should help it for next time
I'm not a real fan of rb30s in toranas but I'd put this motor in it for sure haha attachicon.gifImageUploadedBySAU Community1446774077.957018.jpgattachicon.gifImageUploadedBySAU Community1446774092.454850.jpg
gosh darn Yeah. :)
Edit.....how the hell does the F word turn into "Gosh Darn" LOL
Edited by GTRPSI
  • Like 1
  • 1 month later...
I picked up my sump today, I was told it was off a bianti series xu1 race car, I'm pretty happy with it.
post-134876-1450247873666_thumb.jpganyone know why it would have all the tiny Alan keys along the side of the sump?post-134876-14502479277795_thumb.jpgpost-134876-14502479627485_thumb.jpgi don't no why they have heated these little spots for???
  • Like 1
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
