Hi Guys,
I'm currently planning a fuel system upgrade to my BNR34 and want to keep things looking stock so i'm putting a Walbro 460 in tank. Holley have finally released their Hydromat products in sizes other than the nascar ones, and I need some help on the positioning of the OEM sock in the fuel tank so I know which one to get. I'm away from my car at the moment and can't pull it apart to check, so if anyone can help i'd really appreciate it.
what does the fuel sock positioning in the tank look like, green, red or other, and which of the hydramat products would suit better?
Option 1: 38x20cm cross
Option 2: 38x20cm cross
there are others here: https://www.holley.com/products/fuel_systems/hydramat/
EDIT: i found this image that would suggest Option 1 is the better one:
and here's a video to see what i'm on about if you haven't seen them in action.
Edited by burn4005
  • Like 1
hmm, true. also saw the 11" square. that would cover the entire base of the tank, and I could just run a longer fuel hose to it so it sits in the correct centered location, with a metal rod as an extension from the end of the stock bracket holding the central fitting in the right place. that may be a better option.
also, does anyone know if the walbro 460 primes itself OK if it is placed in the stock location? or does it need to be located right at the bottom of the tank?
Edited by burn4005
Only the pierburg pumps like to prime like that, not sure how the Walbro will go. A large external will do the job nicely it seems...
I wonder if the magic part is ethanol tolerant?
  • 6 months later...
Incredibly, I've made zero progress on this.. my car has been at a workshop for months and months having the engine built for track work/quaife front.
I have a bunch of stuff that i need to do once I get it back, but this is still on the list. I'll get some photos of inside my empty tank and work out how to progress with this.
I have a few things to test, namely the flow performance of the oem jet pump at various rail return rates, I have a high flow Sard jet pump that I can swap in if it works better. The pumping over from the other saddle straight onto the hydramat will increase its effectiveness greatly.
If its inadequate I may look into a lift pump actively pumping from the other saddle onto the hydramat.
Edited by burn4005
  • 7 years later...
I'm running a R33 GTR circuit car. It's on Slicks, E85, 800hp. All the good stuff. Sequential Holinger etc.
I have Frenchies earlier dual pump hanger - It seats two Walbro 460lph pumps on the bottom of the tank next to each other.
I've run that tank as low as a quarter while racing and have not had any issues with fuel pickup at all. Radium rail and end mount reg.
Always logging the fuel pressure.
Hydramat might be good, but you might be overthinking it too mate.
Edited by The Mafia
  • Like 2
  • 3 weeks later...
other option is radium do an in-tank surge setup for the R34 tank.
hides it all away and very neat. not a huge surge capacity but you can't use that much fuel around corners anyway.
20-070.jpg?20210309055629
Edited by burn4005
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
