I have a spluttering noise coming from my exhaust, sounds like its blowing bubbles. Its only happening when revs are dropping back to idle though, and i am in neutral. So If i rev it up a bit over 2000rpm and let the throttle go then u can hear it. I cannot notice it while driving.
Last week I did an oil and oil filter change, fuel filter change and spark plug change. All was fine till last night when i first noticed the noise. I cant imagine this having anything to do with the problem.
Can anyone give me some help as to what it might be? Not sure if its drinking more fuel yet as i have not driven far enough to notice but it almost sounds like there is liquid in the exhaust.
BTW. There has been no rain and i have not washed the car.
Damo
https://www.sau.com.au/forums/topic/45456-spluttering-noise-from-exhaust/
Damo
I used to have this problem with an older car in the days of the good ol' Carby's.. Turned out that it was running quite rich, which created the gurgling and occasional backfiring.
have you installed a after market computer recently? what type of fuel are you using? have you made any modifications to your car recently besides the standard maintenance stuff?
Cleaning AFM with carby cleaner is a really good idea, i did it yesterday and the car runs a lot better and smoother now, plus a bit of a hunting problem that my car used to get after a good thrashing has gone away so give it a go......
No recent mods, the fuel is bp ultimate and ECU is stock.  I might try resetting the ECU today and giving the AFM a clean.
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
