How do people feel about this list? I've edited up an old SAU list for an event that's coming up soon that I'll be assisting with scrutineering.
I've got a bit of track day experience and know my way around a car well enough.
This is not a door to door racing event and will be a small sprint day run under AASA regs.
Exterior
- Brake lights working.
- Windscreen - clear visibility and no cracks.
- Battery - secured firmly.
- Battery Triangle Affixed.
- Tyres - check tread, valve caps fitted.
- Wheels secured firmly.
- No fluid leaks, oil, brakes, gearbox, etc.
- Covers on fluid reservoirs, clutch, brakes, power steering.
- Worn or cracked belts and hoses, cracked or worn fuel lines.
- Accelerator - Must be free of binding, throttle return springs safely attached.
Interior
- Brake pedal - Not low or spongy
- Steering wheel - boss kit secure, grip not loose etc
- Seat belts/harness - secured, sound operation and condition, within date range.
- Front seats - secured firmly, within date range.
- Fire extinguisher – 1kg min securely fixed, metal bracket, firm clamp, in reach of driver, gauge in green - AS1841
- Doors handles function internally/externally both sides.
- Helmet - No physical damage visible AS1698 sticker.
- Cage check, secure, padded where appropriate.
- Engine kill switch operates if available.
- No loose objects, spare wheel, jack, tools etc. removed.
Extra things to check at home before you arrive:
Suspension check - Seals/bushes, etc.
Exhaust - check for secure mounting/leaks.
Bolt check - Cage, seat, suspension, wheels.
Brake pads.
Steering connections/couplings.
Worn/cracked hoses/fittings/couplings/etc.
https://www.sau.com.au/forums/topic/454568-scrutineering-checklist/
Looks pretty good. Other things that scrutes have looked at (in rallying anyway) are battery terminals correctly insulated (in case of accident / rollover)
- Do the valve caps matter? I was once told I had to have metal caps - WTF? Must have been in the sup regs for the event, because it wasn't a CAMS requirement
- Do you need to test the kill switch? I haven't got one so don't know whether it gets tested
- Why do the harnesses need to be in date? Is it a requirement for the type of event? I know that for higher events it is a requirement, but didn't think that track days came under those reg
- Fire ext - stamped and in date? (this one always opens up a can of worms)
- Do they need to run catch cans?
- Bonnet fixings - ie secondary catch if running modified latching mechanism
- Cage is a bit of a funny one - if one is fitted, how will you know whether it's appropriate?
- If any QLD registered cars enter, they must carry a CTP extension for the event. Taking the plates off does not count!!
Cant think of too much else. Main thing is if the car looks fairly well presented, generally these things will be well looked after.
Cool list Dan,,,
- Brake lights working. I'm a firm beleiving in all lights should work,,,foggy days at Wakie need headlights and tail lights. It also helps if you can flash your headlamps at slower drivers that are not looking in their mirrors.
- Windscreen - clear visibility and no cracks. Wipers and washers again are great in foggy and/or wet conditions.
- Covers on fluid reservoirs, clutch, brakes, power steering. If you mean those wrist band type covers,,,then no to that,,, thats was started by the drift guys and is not necesary.
I have been harrassed for non metal valve caps,,,somewhere on one of the leading tyre manufacturers websites they claim older valves will leak air at speed.
I have also coped it about no insulation on battery terminals,,,still not understanding why.
Cheers
Neil.
The insulated battery terminals thing is when the battery is close to sheet metal (usually bonnet), and slight deformation of a panel can short out on a terminal. If the battery is tucked away in a box, then this isn't as critical.
Yeh it's probably a mindset - as soon as they see naked terminals they get nervous. My first impression of your photo was the same, despite there being nothing nearby that can short the terminals. I guess it's very low risk, but I have always strapped some poly or insertion rubber around the clamps out of habit. Takes fk all time and is one less thing that a scrute can pick on.
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
