Just wondering what examples if crank girdle blowing out you have? Considering "Vlgod" split a block lengthwise under the head studs and the crank apparently stayed in after running absolutely heaps of 7 second passes with the block . block split with 70psi boost.....
This thread so much negativity. saying why do it why this why that. whats the point. reminds me of a inspirational speach i heard once.
"Dont Listen To The Naysayers"
"How many times have you heard that you cant do this, and you cant do that, and its never been done before."
"I love it when someone says it has never been done before"
"That means when i do it, it means that im the first person to have done it"
"So pay no attention to the people that say it cant be done"
So i say Keep it up. :D
  • Like 1
what Mathew said!
whatever happened to doing something different?
bloody hell, there's a dude building a torana hatchback on here with full r32 gtr running gear...
Let's see something original, some innovation and some skilled fabrication!
geez if he has the time and budget to do it i say go for it, i can't wait to follow the build and see the results.
or let's just be like a whole bunch of other modified skylines on here and not have anything unique...
  • Like 1
When you say you want to build something, you really mean throw money at something, right? Cause if you havent even run a tape yet, I would be surprised if you know which end of a hammer to hold.
School holidays already?
  • Like 1
Just quietly the R35's 4WD system is what makes it such a monster, and all the computers. If you can drop those in the 32 and you will have a monster of a car.
The engine by itself? Apart from people going "oh cool look at that" what does it bring to the plate?
Otherwise you can make just shy of 500hp with -7's on corn syrup. And that's on a standard Rb26....... Let alone bigger twins/Big single/stroke etc...
As much as i would love to see this be done, for the price? you could get a much better car.
  • Like 1
wow, judgmental much
but your right, those hammers are tricky
ill go watch a youtube video and see if i can get it down pat
well your right about the RB being a good choice,
but having said that, i think its been done so much we know exactly what will happen
i can even go online and find a dyno chart for the same turbo and cam setup ill prob end up choosing
if we dont push the boundaries we wont progress,
just a little background on myself, i design and build products for a living,
in my life, i always want to do something different,
some times i win and its all fun, sometimes it explodes and we have to learn from the mistake
Do it mate, seriously you will have a lighter motor that sits further back in the engine bay and have 3.8L out of the box, a few bolt ons and it will make big power with a responsiveness that any RB could only dream of, so except the cost its win win win
You probably should learn, you might need one, you know, because you don't know if it will fit between the struts or not yet...
Seriously, you make a thread on a forum about your big fancy plan, when in reality, you don't even have a plan.
Not saying it wouldn't fit... But if I was planning on spending a metric shittonne of coin on a massive swap job, that would be the first thing to do. Just to know exactly what I am dealing with...
GL anyway... I'm sure this thread will be 20 pages long before there is a pic of progress...
Edited by MagicMikeZ32
its amazing the response,
its as if people want this project to fail,
for you info Magic Mike
i already measured the engine bay of a stripped R32 Gtr
measured all the relevant distances from the surface of the bell housing area and the center of the flywheel and the front diff of the rb26
i bought a r35 bell housing so i can get the bolt pattern
got quotes for all the work involved
found all the guys to make the parts,
found the engine, its in another state, and before i waste that guys time with a list of measurements i need,
i thought i would ask the experienced guys on this forum,
i wanted to know if it has been done, or if anybody knew of actual hurdles,
all im getting is people telling me im stupid
which i said was the case in my first post
so what your saying is, i should know everything i need to know before i come online and bother you,
i thought this was an exchange of ideas and experience
  • Like 1
wow thats a lot of info
well ok,
it HAS to be AWD or its not worth it,
the diff ratios are the easy part, and CV joints are much more forgiving than people think,
the diff and hubs can be misaligned a bit and work fine, the whole point of the CV is the flexible transfer of the power, they have a range they can work with
the biggest question is will it fit, so jay-rod is right, we have to get the tape measure out
and i think people forget the "waste of time/money" expression was used before, on people who wanted to get 1000hp out of a 2.6L
and now guys are doing that all day every day.
in my mind a car with the same engine as a R35 but 200-300 kgs lighter is a MASSIVE incentive
just a small increase in boost on the stock engine some tuning and we might crack 10 seconds
and the engine would be relaxed and comfy so it will last longer,
then if it worked, a big IF, people would know that its possible and try other interesting builds
Sure sure mate. Good luck with that.
Over and out
Go Hard Or Go Home.
on another note have you even thought about where all the intercooler pipe work is going to go? like will it even fit behind the bumper or are you going to have to customize the radiator area /front structure of the car to make it work? wouldnt mind knowing your plans for all this. and TBH i think the Twin Throttle bodies are the least of your worries. as said above your going haltech and there capable for fly by wire systems...
i thought the haltech would be ok too,
but i rang haltech and they said i would need to convert over to a cable system
there is a way to go around this and keep the electronic throttles
but the 4wd system in the r32 will work better with a traditional TPS
this is what the guy from the ecu wiring company said
as for the inter coolers, i will make it fit,
the block is shorter and the radiator fan is gone the one i will use to replace it will be slimmer
there should be enough room for a custom setup
im pretty good with cad and i have a team of fabricators that are good at welding pipe working for me
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
