a) vehicle that can beat 1000cc bikes.
b) 32GTR
c) vehicle with VR38DETT
pick one. especially if you would like the project to not drag on for more than 2 years.
Let the haters hate.... You seem keen and have done research into it.
Would be one of the firsts in a 32 gtr but it wouldn't be the last if all goes to plan.
Biggest challenge would be engine bay clearance and obviously as previously stated gear ratios etc.
You got the motivation and that's all you need . Good luck hope to see some photos soon;)
And if all else fails you've got a nice engine to stick into another car !
  • Like 1
NOW THATS THE REASON I POSTED
big thanks mate
your search skills are MUCH better than mine,
things we learnt from that video,
IT BLODDY FITS,
ITS AWD, he has slicks on the front
the is actually alot more room than i expected
now im much more confident i can make it work
IM BUYING THE ENGINE
YOU LEGEND !!!
  • Like 2
Really, where cause as far as i can see only the apron is custom, the factory strut towers and full engine bay (other then apron which makes no difference) are still in place
Frankly if you people dont have anything nice to say or constructive advice, feel free to not comment, this is the build thread not wasteland so move on
  • Like 4
the reason he has a custom radiator support is to help him fit those giant turbos, his custom inter cooler and the radiator in new locations
mick is right, the strut towers are still untouched
im running stock turbos, if they fit in the tunnel that is
as the vr38 V6 is shorter than the rb26 inline 6 in the north south direction, there will be plenty of room to run the piping
As guessed the VR38 is pretty much the same as a VQ.
Nice find on that forum thread
Kinda kicks all the nay sayers in the balls :P
This is what he had, an RB, and he wants faster, so.....VR38 can prob do that in such a light car
His fastest time of 7.4 seconds is quick as fck, maybe see if u can get in contact with him.
Edited by jay-rod
quick question boys
inittaly i will run the car on the stock gearbox till i get it running right
then the gearbox will explode, thats nearly guaranteed
which way should i go,
im thinking OS GIKEN gear set
anyone have any better ideas,
i still want a normal car, no dogbox or sequential
    • It's excellent but I'm still breaking it in so I'm not 100% sure where it'll end up. I would say it's about 15% heavier than stock and the smoothness of the slip zone is quite progressive but you need to be a little patient compared to stock or it'll bite hard and stall. Stock I got away with absolutely horrid clutch control. Like I said before I couldn't even tell where the clutch would grab when it was stock so releasing way too quickly without enough revs it would just slip and the revs would drop lower than ideal but that would be the end of it. Currently there's a bit of a nasty clutch judder if I don't apply enough revs + find the exact wrong point of the slip point in the clutch pedal but it feels like it's slowly resolving as I drive it more. I would not recommend the competition clutch unless you really need the extra clamp force. I think this clutch combined with the Nismo operating cylinder is going to be exactly what I want. Enough bite that you need to remember the release point to avoid stalling or rough shifts, but progressive enough that it's not hard to drive by any means and not heavy at all. I tried a "super single" clutch on my friend's 997.2 Turbo 6MT and that was absolutely horrid. It runs an electrohydraulic power steering pump for the clutch power boost so there's zero feedback in the clutch pedal and there was a horrific clutch shudder well after break-in due to the lack of marcel springs or hub springs in the friction disk. It felt like the slip zone was the thickness of a single toe twitch as well so it was almost impossible to avoid stalling it unless you gave it a ton of revs and just dumped the clutch instead of trying to be smooth with it. I was terrified of pulling out in front of traffic. I have also tried some kind of "super single" on an EK9 and that makes this twin plate Coppermix look like a stock clutch. Releasing the clutch pedal even slightly too quickly feels like you're getting rear-ended. The pedal is extremely heavy as well and there's no vacuum assist like the GTR.
    • Yeah, well I was probably way underguessing the $300 figure anyway. Just multiplied a "normal" by 4 for the purposes of pointing out it's not cheap, particularly if it has to be repeated.
    • We have an alignment shop out here that does what you're talking about but he wants like 800 AUD a pop. DIY is "cheaper" but once you start accounting for the value of your time I'm not sure it's worth it.
    • The main catch phrase for any car is "the eye of the beholder", and "personal tastes and preferences" And as for the plastic "flares", I honestly think they look cheap and tacky, and I cannot see them aging well, maybe if they were body colour they might look better to my eyes, but, I would still prefer it the were more like the older WRX STI models that had the wider body metal panels In saying all this 5hit, I wouldn't buy a new WRX again, even if it had the wide body metal panels
