i spoke to a custom garage today, he is doing some numbers and getting back to me,
he is extremely confident,
and has done things like this before, not the exact same, but swapping engines with jap turbo cars
What happened to your team of fabricators and cad skills?
wow you guys are really critical
have you ever heard of collaborating
you cannot do everything on your own
i have different guys making different things
all these components have to come from somewhere
gearbox adapter plate
custom CV chafts
custom tail shaft
custom exhaust
ECU wiring
throttle bodies
inter cooler piping
custom engine mounts
custom bonnet
fuel setup
custom panel beating the engine bay (big hammer)
you want me to make all that on my own, ill be here for the rest of my life
so i have found the best guys in each area to help me out
sorry if i spread the work around
my guys have certain skills, they cant do everything
now if i said i had a team of magicians, thats a different story
Wow, yes its going to be expensive, he said he didn't care about cost, if I had money to throw around I would get a Toyota 4 litre V8 in my 5 and then blow it, is that smart or stupid, who cares what other people think, I don't.
As for the RB, yes it was a good OLD motor, but by Christ there are better newer powerplants out there.
Stop posting, buy it and build it, post in here when its done.
As for the fab work, you need a pelethera of subject matter experts and fabricators for a project that involves lots of mechanical and electrical engineering.
Its been done before, its not new, just make it happen.
BTW, all this talk about street racing makes me think you are a pimply school kid, if this is indeed true, please go away now, thanks for the LOLS everyone.
Quoted for truth
Looks like it bump steers like a mofo! What's with the manual stick AND the tiptronic? Wierd....
Sounds like he's running 044's too....
Looks more painful than enjoyable that's for sure!
  • Like 1
looks like it runs an air shifted box of some sort...liberty maybe
Winner!
It is a drag car only, they have run mid 7's with an RB... now with a VR inside.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
