Hi guys,
Keen to move this stuff so all parts nego. All have come off my 32gtr.
Consolidating in this thread so mods please delete others if theres an issue.
1. Speedy Holotype R Wheels (5x114.3, 17x8 +35) w/ Kumho (zetum) 235/45 tyres - $600
Wheels in excellent condition, no marks. Tyres have plenty of meat although bit of camberwear.
Square fitment
2. Nismo 600cc top feed, direct drop in injectors x6 - $450
Just got them back from being flow tested, cleaned and serviced. Two injectors are flowing slightly higher than the rest hence the cheap price (these retail for >$1k for a set of 6, replacements are ~$150 each). All are individually marked and bagged.
3. Nismo Front Pipes, suit BNR32. 60mm-in, 75mm-out. - $300
Flows fine at 300rwkw, perfect fitment and great quality. No dents or leaks, could use a polish if you like to look under the car.
4. Venom 3.5" high flow cat, brand new - $300
5" body, 100cpsi (most free flowing out there i believe). Direct bolt on for 32/33 as well as s-chassis cars. Comes with gaskets. selling as when I pulled my cat out i realised it was gutted so keeping as is.
5. Rb26 AFMs + Blitz intakes - $350
Working perfectly when removed, no plugs. OEM RB26 afms, car has 120,000km's on the clock.
6. HKS EVC3 electronic boost controller - $150
Just removed. Works perfectly. Has scramble boost, low/high boost settings, as well as auto learning.
[pics to come]
7. RB26 resistor pack (for injectors) - $100
Just removed. Needed if you want to go back to low impedence injectors (has both male and female connectors). Has been spray painted black in a previous life (along with pretty much the rest of my engine bay)
8. HKS Metal intake gasket kit, brand new - $110
Includes intake manifold and throttle body gaskets. Purchased but no longer needed
9. R32 boot trim/lining pieces - $15 each or take it all for $50
all in perfect cond. both side pieces, rear piece and the cover for the attessa pump.
post-24058-0-08861400-1426045382_thumb.jpgpost-24058-0-15625900-1426045437_thumb.jpgpost-24058-0-77484400-1426045461_thumb.jpgpost-24058-0-32104800-1426045489_thumb.jpg
10. LED Replacement bulbs for R32 Triple Gauge Cluster - $5 for a set (all 3), 3 available
Easy as swap to do, replace your now busted bulbs with bright, white LED ones. Gives a much more modern feel to the interior of the car. Will be putting up a DIY soon.
Located in Wollstonecraft NSW. Can post smaller items at buyers expense. Will also trade for items of interest (harness, steering wheel/boss kit, N1 vents etc.)
Cheers,
John - zero four 31 083 394
Edited by Jaeyon
Price drop on nismos to $400ono.
Will also separate AFMs and Blitz intakes - $150 for both intakes, $200 for both AFMs
Also have:
Apexi intake to suit rb26, selling as not needed. Purchased off forum member here just recently, was test fitted to his car for a week before being taken off. excellent condition and bolts straight up to stock and z32 afms. - $300 posted
  • 3 weeks later...
Nismo singleplate coppermix for r32gtr/r33 gtst push type boxes -$400. Comes with clutch cover, pressure plate, nismo flywheel and bolts
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
