I took a trip to the states and saw some guys using Cadillac CTS big brake calipers and evo rotors, and from what they say it cost the 500 dollars or less for everything up front. Almost all of them I see is on s14 silvia or s14 240sx has any one tried these setups on the r32 gtrs as it would be a great up grade for very minimal cost. Im thinking about doing it. I know I have done it tge next way around. I have put r32 gtr brakes on a s14 silvia. And only the metal gaurds needs to be straighten out for the bigger rotors everything else fits. Ive even did it from r34 GTT to s13 and only the bolt holes needs to be open up on the front knuckles. (Caliper mounting area) plus the metal plate being flattened out.
Anyone seen this before?????
https://www.sau.com.au/forums/topic/454655-cadillac-cts-brake-upgrade/
I havent seen it, but am interested.
From what I can tell they are the same calipers as used on our Holden commodore ss redline. The front calipers and rotors can be purchased brand new just over 1000, but the rotors are wrong stud pattern for Nissan. Haven't seen price for calipers in their own but are probably reasonable.
At enjukuracing ask for Andrew he has the whole setup for 550 dollars. Look at the follow photos of the part numbers. Its dead cheap. Even worth the effort. I sceen shot our conversation. The part numbers are there. They look bad as☆ on the cars and are very very big he also have me a quote at 1100 if I wanted a 2 peace rotor, but at the 550 its worth the effort.
From what he is saying only the brake lines would be in question. The z32 300zx should work on a r32 gtr though. Seems like some strict laws in Australia. Hmmm:angry: damn governments.
  • Like 1
What size rotor are they quoting?
These need a 355mm rotor at minimum, guys are selling them with a 350mm rotor and it's causing issues...at least that is what a reputable brake company is sydney told me.
Although If I can fit 355mm rotors under my wheels, I'll be all over this
We are getting a lot of VE Commodore owners using these calipers with larger rotors that they purchase from us here in Melbourne.
They buy the calipers from the states dirt cheap (so they tell me) and they bolt straight onto their VE's with bigger discs.
Appartently much information on some Aussie GM forums, its a very popular conversion ATM.
LOL...oops
1977480_1467919253491254_875719207386226
10374072_1458557351094111_33752211508925
YAY..someone doing it right
10469417_1481141688835677_70998644059160
Looks a reasonable upgrade. Neat brackets too. Does anyone actually know the piston sizes of the calipers and whether they have different sized pistons?
Also, anyone gotr pics of the pad, rotor edge? The caliper doesnt appear to saddle the rotor all that tightly?!?!
Yeah lots of VE/VF owners doing this upgrade.
It's reasonably cheap, not $550 cheap though once you get to AUD.
Hmm. Well I guess your right there. For once im on the lucky side. Lol
Those are the 4 pots, 2012 model moved to 6 pots. Ctsvbrakeswap (link above) will hopefully have their production bracket available soon to suit these using z34 14" rotors.
A member on one of the american zed forums made a small quantity of brackets also but these required a fair bit of modification to fit, I'll probably give the above brackets a go once released
Edit: piston sizes are different & from what I can find are 30, 34, 38
Edited by lidz
    • What could be causing my clutch problem besides a bad master or slave then? Both those parts are new
    • Just came across this, but in QLD I start leave again in 2 weeks, if it is still available I might drive up and check it out Unless, @MBS206 do you live near here????, if so I could hit you up with a finders fee https://www.gumtree.com.au/s-ad/hope-island/auto-body-parts/nc-mx5-factory-hard-top/1328976391
    • My hold point for future mods is that I want a OEM detachable hard top first, but, finding one is a pain, MX5 Mania are looking for one for me, but, as hens teeth are more common, finding one in Australia is proving problematic  I can get a OEM one from overseas, hell, you can still get new ones in 'Merica, but, shipping is a absolute killer and I cannot justify the cost, or the risk of it being damaged during transport As for the aftermarket hardtops, whilst they do the job of being a hard top, and are fine for a track car, they don't seal well (read: leak like a sieve in the rain), and you need a plastic/poly rear window, plus they are a bolt in option only and not made to be easily removed I liked how the hard top on my NB could be fitted, and removed, by myself, in less than 5 minutes I know it sounds bad, but I'm waiting for someone to write off a car with one so I can swoop in on their pain, it will go to a good home though, so my guilt of this is tempered
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
