Applies to 4 pistons. Serious. Not theory. Shit is real.
I need.to read up on all of this. As well as bring some of these concerns to the guys that run them over here. If I was to buy a brembo big brake upgrade. I would guess all these issues would be addressed. This is crap because im all about functionality then looks. Wow. I can see myself basically taking a course on these valid points. Here goes the reading. Ok. If it was you guys is there any way of addressing these problems feom the info you've seen.
Thw bleed screw one is valid. Any others???
master cylinder and brake bias
The 6pot would be overkill, like Fred Flintstone Panic Braking.
So what is the difference between 6 pot and 4 pot? Running the same rotor and pad will often mean less braking power!!!!!! NOT more!!!!!!
There are loads of threads posted about this sort of the stuff. Maybe people should read the EVO caliper thread to get an idea. People shoudl think of brakes as simply heat sinks. So you are not trying to stop quicker, but rather stop more consistently. So you handle more heat largely with the rotor so everything the caliper does it based around what the rotor needs.
Good pads and fluid. Good curved vane rotors of bigger diameter...and frankly its pretty silly to use less than ideal lug mount caliper adaptors rather than go to a proper radial caliper. Especially when the piston sizes are going the wrong direction. ie the bigger the rotor you choose the run you actually want to go to a caliper with less piston area...NOT more. So going from a 280-296mm std Nissan rotor to a 355mm rotor you dont want to be going to a caliper with bigger pistons than the std 40.4mm pistons
  • Like 1
Off topic but would there be any advantage to using a larger rotor with the factory caliper via the use of an adapter of some sort? Forget the cost to benefit ratio I'm just curious whether it would increase performance and reduce brake fade.
Just had the thought because more people use 17/18 inch wheels than the factory 16s
Edited by Blackkers
Yes definitely better. To actually be able to fit an adapter though the difference in rotor size needs to be a fair bit.
And then you start to get into the problem of the larger diameter rotor not fitting nicely into the shape of the caliper or the pad not sitting nicely on the rotor.
So it works for some cases, not for others.
  • Like 1
hugely overpriced given what the parts cost, 6 pots can by had for us$500 plus shipping brand spankers.
Not even that.
I priced them at US149ea
Even Jegs and Summit have them for around 155-160us ea
Brackets are 160ish US
The Calipers are cheap because GM order them by the millions. So of course, they cost f**k all.
997 GT3 cup calipers arent that expensive either.
Yeah about $700 when I last checked.
Problem is cost to get them fitted makes things expensive - and the time factor.
Hence a 'bolt-on' Skyline kit, ready to go and can be done in a couple hours, is always handy.
Very true.
Been looking at those brackets that US mob are making....cant say im a fan....look like they would flex a whole bunch! being 10(ish)mm aluminium.
Though I may buy the 4 pot brackets, and If I'm unhappy, have the bracket remade in 4140 or something.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
