Applies to 4 pistons. Serious. Not theory. Shit is real.
I need.to read up on all of this. As well as bring some of these concerns to the guys that run them over here. If I was to buy a brembo big brake upgrade. I would guess all these issues would be addressed. This is crap because im all about functionality then looks. Wow. I can see myself basically taking a course on these valid points. Here goes the reading. Ok. If it was you guys is there any way of addressing these problems feom the info you've seen.
Thw bleed screw one is valid. Any others???
master cylinder and brake bias
The 6pot would be overkill, like Fred Flintstone Panic Braking.
So what is the difference between 6 pot and 4 pot? Running the same rotor and pad will often mean less braking power!!!!!! NOT more!!!!!!
There are loads of threads posted about this sort of the stuff. Maybe people should read the EVO caliper thread to get an idea. People shoudl think of brakes as simply heat sinks. So you are not trying to stop quicker, but rather stop more consistently. So you handle more heat largely with the rotor so everything the caliper does it based around what the rotor needs.
Good pads and fluid. Good curved vane rotors of bigger diameter...and frankly its pretty silly to use less than ideal lug mount caliper adaptors rather than go to a proper radial caliper. Especially when the piston sizes are going the wrong direction. ie the bigger the rotor you choose the run you actually want to go to a caliper with less piston area...NOT more. So going from a 280-296mm std Nissan rotor to a 355mm rotor you dont want to be going to a caliper with bigger pistons than the std 40.4mm pistons
  • Like 1
Off topic but would there be any advantage to using a larger rotor with the factory caliper via the use of an adapter of some sort? Forget the cost to benefit ratio I'm just curious whether it would increase performance and reduce brake fade.
Just had the thought because more people use 17/18 inch wheels than the factory 16s
Edited by Blackkers
Yes definitely better. To actually be able to fit an adapter though the difference in rotor size needs to be a fair bit.
And then you start to get into the problem of the larger diameter rotor not fitting nicely into the shape of the caliper or the pad not sitting nicely on the rotor.
So it works for some cases, not for others.
  • Like 1
hugely overpriced given what the parts cost, 6 pots can by had for us$500 plus shipping brand spankers.
Not even that.
I priced them at US149ea
Even Jegs and Summit have them for around 155-160us ea
Brackets are 160ish US
The Calipers are cheap because GM order them by the millions. So of course, they cost f**k all.
997 GT3 cup calipers arent that expensive either.
Yeah about $700 when I last checked.
Problem is cost to get them fitted makes things expensive - and the time factor.
Hence a 'bolt-on' Skyline kit, ready to go and can be done in a couple hours, is always handy.
Very true.
Been looking at those brackets that US mob are making....cant say im a fan....look like they would flex a whole bunch! being 10(ish)mm aluminium.
Though I may buy the 4 pot brackets, and If I'm unhappy, have the bracket remade in 4140 or something.
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
    • No I got mine from a friend that had fabricated one … but I had to fit it to my setup which was a hks turbo setup. His was a Garrett -7. So one of my turbos was not a flange for one side … then I had a leak in the welds I had to find a weld shut … in the end the setup was decent priced but I spent a lot to get it fitted. A couple companies I checked would make it but you’re talking 7-9k aud with titanium. No joke mine was 6-7k even second hand after I had to fit it in Hong Kong … labour is expensive here.
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
