Registered or not in SA makes no difference when selling.
It's only when transferring rego from another state
The fact is your car snuck through without meeting the proper ADR requirements. That's not SA's fault.
Yes indeed.
How the car got passed a Roadworthy Inspection for 1st Rego in QLD beats me!
Because not pasting the 'Import Approval Sticker' on, the importer can face a fine from the Aus Gov!
Oh and yes that is right.
The bike I bought in VIC was previously registered in SA.
I only had to visit the Service SA office to get it rego'd again.
Even though it would have failed for sure because of non ADR stuff that was aftermarket!!!
Edited by PaulReeves.com - GPOWER.TV
When I can get it rego'd in another state for the same price with HID's still intact.cannot, its an ADR rule, Australia Wide & is done on all imports, just part of importing a jap car unfortunately.
Posted Today, 02:21 PM
That's why it is VERY IMPORTANT to have a close friend who does Blue, Pink Slips & Removes Defects in your state!
It's not just me, I know a HSV Clubsport-VT running a Stage 2 Cam that is registered.
Only because of him knowing that person who does inspections for him, can he drive it on drive days with the club like Historic Rego in a way :)
What are the strict VIC rules that you hate & others?
They limit mods to the intake system to a certain number for example. It's 1 or 2. Not based on what those mods do...just the count of them. There's all sorts of similar silliness.
If you got nothing out of Vehicle Standards via e-mail, there's always the phone or going down there for a chat. I suspect they get hundreds of useless e-mails every day!
  • Like 1
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
