Can anyone please tell me how to clean the yellow tinge looking crap off the exterior of the headlight lens?
A tinting place used 'fly spray' on my mums car, that worked, but not on my set of lens!!!
Anything else works or how to get them cleaned/restored to near new again?
Because the eBay Angel Eyes (aftermarket ones) only fit the Coupe models!!!
usually the yellow tinge can be sanded off with fine sandpaper and then some plastic polish.
I'm currently trying to clear my clear cam cover using hydrogen peroxide (found a guide online) will let you know if it works as it should also apply.
  • Like 1
Used that guide years back, and actually did the procedure on headlights that were previously "fixed" using can spray painted clear yesterday. OP look no further
  • Like 1
What difference from the INVISION compared to the GLASSYLITE?
Anyone here used both of these products & have their own views & experiences on this???
I do headlight restorations all the time and for an off the shelf kit, the INVISION one is probably the best one out there as it gives you everything you need, and most importantly a proper UV coating to go over the headlights.
If something proper isn't put on the headlights they will quickly start to go yellow again.
The best process is multiple stages of wet sanding to remove all imperfections from the headlight, multiple stages of machine polishing to remove the sanding marks and then applying a properly bonding UV agent (I use Gyeon Trim).
Good luck :)
  • Like 1
  • 2 months later...
I got the Meguiar's Headlight Lens Correction Kit from Repco $65.
Includes the Sand Papers #1-#4.
Buffing Cloth with Polish & the UV Protectant Sealant Polish as the final stage! :)
I done mine in about 1:30hrs.
Could of been done neater with much more time as you say 'machine buffing' to remove all sanding marks from the previous user!!!
Here are the pix before & after of mine.
Road actually looks brighter now after the procedure with the HID's fitted ;)
