Where in the fuel system is the best place to place a fuel cooler. On the feed/pressure side, or the return side back to the cell. Low pressure. Im working it out right now and if I was to guess I would say the return. :huh:
Edited by MJTru
https://www.sau.com.au/forums/topic/454679-fast-question-here-about-cooler/
Thanks im running two 044. Was reading up a bit on if they would heat up the fuel a whole lot. What ive came up with is my regular needs to be changed. I need one that return the fuel right from the regulator and not the rail to the regulator. That would be away to keep fuel temps down. As well as putting a tee on the surge tank return and the fuel regulator return and sending those line through the cooler before it goes back to the cell. Damn im pull what little hair I have out my head counting fittings and all. Thanks again mate:wacko:
Edited by MJTru
Just keep it simple man..
Flow should be from your lift pump which feeds your surge tank. Those two 044s feed the rail .. Fuel is returned from your rail through the reg.. After the reg It will the run through your cooler returning to your surge tank
I don't understand what you mean with the T's, you want all your fuel to be cooled on the return
Draw a diagram to figure out your fittings,
Does that help?
Does that help?
Ok im doing the diagram now. Lol.
It's still hell. Fitting wise. But I dont agree with the fuel returniong off the rail. I should just feed that with pressurized fuel. If it returns off the rail to the regulator. Thats added engine heat being pass within the fuel that the engine is making. But they have FPR that has the pressure goes to it and from the regulator it goes (pressurized here to the rail) in the regulator the regulations of pressure happens and it then returns to the cell. I hope you understand that part. Now for the Tee part. Lol bear wit me here please.
So as the fuel is being returned to the cell it will go through the cooler at that point I want to take the over flowing fuel that the lift pump is pumping to the surge tank = over flowing fuel as well and tee that into the cooler with the fuel coming from the FPR. That way all overflowing fuel is cooled. Ha there. Can you see it now. :huh:
Edited by MJTru
Not sure you've got it right but maybe you're just saying it wrong. You need to do like GTR Joey says. The fuel in the rail is pressurized by being blocked from leaving by the regulator. To paraphrase:
Tank>lift pump>surge tank>044s>filter>rail>regulator>cooler>tank.
Saw a great OEM fuel cooler today on an old Merc, the return line went through a nice little coil wrapped around the aircon line. Would obviously only work when the aircon was on, but that would be most hot days I guess.
Oi Scotty, im surprised you didnt mention variable speed fuel pumps or pump controllers to reduce the need for a cooler....go on now, i always enjoy your posts on fuel setups :)
  • Like 1
Lol. I had already gotten these 044 pumps so I cant go the fuel lab stuff. Live and learn. Next time. Ok I did say it all wrong. Here goes again.
Ok there are some FPR out there that has the fuel pump pressure go straight to them. (Pressure to FPR) insted of the fuel rail. Now these types of FPR are away like most are from the engine and are commonly located on the fire wall. Internally speaking now there are up to 4 feed lines going to the rail and when referring to this setup there is no return from the rail. The only return in from the FPR. the only difference in the two setups are one always flowing fuel from the rail to the FPR. The other just pressures the rail and returns from the regulator.
I feel a regulator of that kind can reduce heat a whole lot. Due to the fact that the engines heat isn't being added to tye fuel on the way back. I think this time around I did the expansion a bit better.
Well, sort of. Most dead regs are actually located at the tank/pump end of the circuit, rather than up at the engine bay.
And in real terms, it's not the circulation of the fuel through the rail that really heats it up. It's the fuel getting thrashed to stupidly high pressure over and over again by really big pumps as it goes around and around that does most of the damage.
If you meant non return fuel systems, the reg is in the tank and the pressure bleeds off. Unfortunately you can't add boost pressure to these regs though and your fuel pressure would drop in relation to the manifold under boost. Not a good thing if like me you run more boost than base fuel pressure.
With a large enough pump you can easily run no reg at all, just using a 2mm or so restriction in the return line. I know this works because I initially tuned the Evo like that before I realised they had a restrictor in the return (intank), and the 460L was flowing twice what the stock pump could. Not something I would recommend though. :P
  • Like 1
Thats intesting. I never thought it would drop the fuel pressure. If that was the case. Here comes a lean situation. I might as well stick with the one I have and run the cooler.
What do you think of the idea of running the surge tank return and the rail return through the cooler.
Or would it be best to just run the rail return through the cooler only. :huh:
That's fine.
The hottest fuel will definitely be the fuel coming back from the rail. It has been through both the pump and the rail. You will get the best heat removal by trying to cool the hottest fuel. Therefore return from rail, regardless of where it goes (main or surge tanks) is the best idea.
I couldn't find a really good fuel cooler so I used a trans oil cooler with 8 an lines in and out. I will make a system under the car to funnel air through it on an angle.
  • Like 1
    • So my R32 GTST has been sitting around at my old mum and dad's place for a few years now...and it's time to bring it home. Main issue I have is that she hasn't been started in about 5 years or so, so I'm not too keen on just kicking it over and hoping that RB20 reputation for being un-killlable extends to long periods of neglect. My plan is to get it running there so I can move it around,  then get it towed back to my place where I can start working on it properly. The old folks driveway is a bad place to start a project like that. I'm getting old too and also haven't stuffed around with cars since forever, so kinda learning this stuff again. So far I've siphoned out all the shitty old fuel and topped up the coolant (thought it was fully dry but took 2 litres to fill the radiator). Planning on hitting the rusty rotors with some brake cleaner in case the tow truck driver gets a bit gung ho loading it up. As far as oil, it's got plenty although it's now dark in colour and obviously needs a change sooner rather than later. Was doing some YouTube research and was planning to hand-crank the motor from the harmonic balancer with a 37mm socket and breaker bar, removing the spark plugs and spraying some "fogging oil" in the holes but there's not much room to get in there with the radiator fan right up against it. Jacking the car up takes too long and I can't leave it half done between visits. So now I'm was thinking of cranking a few times it using the starter (removing plugs and spraying oil first). Reckon there's any chance it will do more damage that way if something's stuck inside the motor? Should I really change all fluids completely before I go any further? Grateful for any other advice you guys have to get her going safely too.
    • Well, that's just wierd. Amongst a string of seemingly benign introduction and request for help threads, we have this one with a link.... to another, unrelated thread inside this forum. Colour me suspicious.
    • Sorry to say, I think that is a pretty long shot on this forum.....
    • sorry, "info" from Lumley here: https://www.lsvcarinsurance.com.au/about-nrma-insurance
    • So it looks like Lumleys are closing other than in Victoria, with the kind offer that another brand from the evil IAG multi-glomerate (NRMA) might offer insurance under their price and conditions if they want to, as an alternative. Lunmleys was good for us because they covered JDM and USDM imports, had 2 car "stable" insurance (ie, insure many cars but max of 2 can be driven at once), covered mods, reasonable overall prices. So, with them gone, who else should I consider? Shannons is last on my list, we used to be insured with them until we found they were helpful at taking premiums but much less helpful at claim time.
