Picked up Volvo XC60 this arvo.
Undamaged paint: tick
All dents gone: tick
New tailgate light lens: tick
Aluminium mouldings: tick
Rubber momouldings: I rejected a front roof moulding. It has two dents and the edge is lifting. Rephotographed and reported to the insurance company.
Other: Offside blinker didn't work and offside rear parking light didn't work. It was just a detached loom.
After arguing through 6 emails 3/side, I finally got consent from an NRMA assessor that the rubber moulding end piece at the front will be replaced. My final straw was telling them that Volvo wouldn't allow the car to come out of the factory like that ie with two distinct dents in it and the upper edge lifting.
Hmm it is unfortunate to hear that it came to that to get that sorted.
It does sound pretty straight forward => damaged items should be repaired / replaced.
Hopefully this will be the last of the hurdles :)
    • I bought one for a 32 and it was junk, found its way into the bin
    • have a look at the other 2 stock rubber strips marked in blue. As you can see, they press against the cooling panel and leave marks. If the cooling unit panel isn’t there, the strip press against nothing therefore have no use. So Nissan was thinking ahead when they manufactured the cars, as they must’ve known people will install the panels in the future. Otherwise think about it, why else would they be there? Therefore that in itself directly infers that cooling panels do something. It might be to stop water and stop some air from going above the cooling panel so more of the air can be redirected between the cooling panel and the front bar towards the condenser and radiator. I tried to take a pic of it while the bonnet was closed but u can’t see shit in the photo
    • @DraftySquash @Duncan i misspoke, or this might be the other way. someone sent me a low res pic of it on It might completely close off the gap in red like in the second pic (second pic has gktech cooling panel on) .The 3 holes are for the plastic rivets used to secure down the front bar. The outer holes on the radiator side go underneath the condenser brackets If thats the case then there’s going to be no air going in through the grill between the bonnet and the bar for the radiator and condenser. Isn’t that bad? I mean less airflow to the radiator and condenser is all I’m saying
    • Interesting. Some of them were tight to lol
    • That's right, simple but works. Run out of load? Rescale the table lol. Want to be lazy and not rescale? Drag the K
