Was about to say the same as Ben ^..... try some rims that fit without the adapter
that means i need borrow set of nissan stock rims....
i just changed the position between front wheels and rear, let's see on Monday.
Or take it pedders for the steering and suspension check. Im pretty sure if you took it to the tire place and get them to look at it. Im sure when you explain it to them they will know whats wrong with it. Better then going back an forward on a forum arriving and no answer is it not.
the hub adapters are brand new. I bought the hub adapters because the vibration problem, but the problem didn't get sorted.
So car drives fine.
Starts vibrating.
You buy hub adaptors.
Is that what happrned or something else inbetween?
So car drives fine.
Starts vibrating.
1. my car has vibration problem when i bought it
2. I did 4 wheels balance, and changed 4 brake rotors
3. bought new rims with previous tyres and balanced
4. bought hub adapters
5. just rotate the wheels between front and rear
still has the problem.
i record a video here, you can here some noise from 20s - 24s when I accelerate the car (around 50-70 km/h) and the ground is not smooth. this noise is from rear. I assume this is caused by same failure.
sure, I will do it when next maintenance.
  • 4 weeks later...
all sorted after changed 4 new tyres and tailshaft balance.
first I did tailshaft balance but my car still got vibration problem
then I went to MRC and they said my tyres are worn uneven. the vibration problem is gone after changed 4 new tyres
thanks all your help, mates.
  • Like 1
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
    • Was that Australia Delivered Duncan? Does it have siren etc?   I used to have remote start on an old 32 two decades ago, it was a cool feature. I used to wake up early in winter for work. Start it and by the time i was out the door a few minutes later the engine was warmed up and the heaters had the car toasty. It was great.    I don’t mine the ambience lighting.  I drive a western star and it has footwell lights and ambient lighting and it’s great! From the pics of seen of them installed in a skyline I think it’s a nice touch
