I purchased a item on eBay to customise a drag wing but didn't work out as I planned.
Damn eBay cwap... I haven't viewed it in person just yet as I'm out interstate working.
Looks like it's just the clear coming off.
3 weeks waiting for this wing and now more delays, not happy!!
Edited by QUP29
  • 4 weeks later...
  • 2 months later...
Update time...
Picked up genuine ganador mirrors in bayside blue, had a win as these are discontinued
Got the sump back today from the diff shop, now with 4.3 ratio's and it's a hi octane sump extension
Surprise surprise engine is in! the harmonic balancer and stock tigger setup is being changed soon!
Edited by QUP29
I've got the head drain that's going back to sump, i had the oil catch can next to the fuse box but looks like we'll need to customise another one as the hypertune plenum extended more then we anticipated, also mite be running another catch can on the other side, all Lines are plumb back into sump.
Edited by QUP29
  • Like 1
Is the Hypertune intake plenum right??? It seems to poke waaaaaay too far away from the engine. The angles from the cooler look like they're going to be all out of whack.
Otherwise looks awesome!
What trigger setup are you using?
V2 hypertune plenum is all bolted on, it did take me by surprise how far it was located.
But we'll cut a hole in the panel, pic below... Piping will be all good just some panel work.
Trigger system is up in the air, we may go custom like in ibomu gtr or modify my standard item
Edited by QUP29
For the $$ a Hypertune costs I'd be wanting it to be a straight bolt on affair and some sort of sexual favours to boot!
Take a look at the Hi Octane trigger setup, I just got one and looks good. Crank pickup works off a small trigger disc that mounts to the back of the timing belt gear. it's quite neat-
Damn nice build!
Thanks for the info on the Hypertune. IT IS A MONSTER. Mine ships out tomorrow!
Didn't expect it to protrude THAT far over! Yet another thing to add to the relocate/fabricate list.
    • Lucky pick up Best to find these things before something horrible happened to the yoke flange thingies I would hate to think what would happen if it dropped the tailshaft  Hopefully the holes are not flogged out in the yokes and it was just the bolts that got munted  As for the hand brake.....ouch, look like the disc got rather hot, and I assume smokey, I recall when I had a front caliper seize on the Commodore, there was lots of smoke and the disc was glowing cherry red when I was able to eventually stop and have a look, and stopping a big heavy car, going down a big hill with some rather high RPM down shifts and some hand brake action is something that makes you think hard about life
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that one side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
    • Very interesting, im not sure how all those complications fit in to running a haltech instead of a stock ecu but I'm starting to think I'm a bit out of my league.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
    • Don't assume the AC relay signal from the ECU is +, some models including Stagea use an earth trigger.
