I had this issue come up yesterday, when i press the clutch pedal all the way in, then release it, it makes a loud single clicking sound. Only happens as soon as i release the pedal. I checked underneath and used some silicon lube spray on the large round spring and some on the piston rod that goes into your firewall but after pumping it a few times, it comes back. I also noticed the little plastic things where the round pedal spring sits are broken It makes this sound 8/10 times i use the clutch pedal. Recently had my master and slave replaced. I checked the welds above and they didnt look cracked.
What can it be?!? I made a little video so you can exactly see what is going on.
i figured out that the master cylinder and the bracket it sits on that connects to the firewall in your engine bay is pushing in and out as i pump the clutch pedal. Already tightened the 2 nuts on it but it still moves out when i pump the pedal. How would i go fixing this?
Master cylinder stopper (a bolt on bracket that bolts to the suspension tower and stops the MC moving forward) would help.....but if it's all moving enough to make noise, there must be something wrong enough that band-aiding it with a stopper would be silly. Look for cracks in the firewall, etc. Find and fix.
Couldn't find any cracks but i *may* have fixed the problem. I pulled back the bolt on the clutch switch nearly all the way back and tightened it. Pumped it a few times and drove it around the block and the sound was gone. I also noticed even though i pulled that bolt back quite a bit, i still havent got any free play on the clutch pedal. Does this mean my clutch is always disengaged so it might cause it to slip and burn my clutch eventually? What else can i play with to loosen up my clutch pedal a bit so i have at least half an inch of freeplay? here are a couple of pictures
The clevis adjuster in your second pic is the place to adjust free-play. If you have none, then depending on how negative the amount, you will either be;
  • only just loading up the throwout bearing, or
  • Applying enough pressure to the throwout to actually start disengaging the clutch.
The first is bad enough, it leads to the throwout having a VERY short life. The second would be worse, but it's actually unlikely that you could apply enough force to make it slip much unless the clutch was marginal for the amount of torque being applied to it anyway.
Edited by GTSBoy
Have a closer look at your clevis and push rod. '
From the photo I think the end of the push rod is actually rubbing against the pedal arm, think I can see some shiny metal on the arm.
It may be adjusted incorrectly and the pedal arm is actually doing the pushing on the push rod, not the clevis.
Then when you release the pedal, the push rod follows out and at some point clicks as it takes up the slack in the clevis pin.
Ok i played around with it and got it working better. I can still hear a light metal grinding sound though when i initially push down the pedal. Can i put some grease where the clevis rod is and some on the clevis too? Hopefully that will finally fix it
Lithium grease is available in spray cans too. The best stuff for aiming down a tube (like your silicone spray) and putting grease more or less where you want it* and having it stay. Don't use the silicone spray. It's not useful for this sort of thing. You could the bearing grease you have (the red stuff), if you can push a bit up there on a finger tip.
*Of course it also tends to go everywhere else!
man, what the hell is going on. It was hard with little freeplay when i was going to work this morning and now its soft as shit with a ton of freeplay now. Im done with it. Im just gonna ride it out and see what happens. 3rd gear is knocking anyway. Thanks for all the help
Edited by IM-32-FK
You didn't report on how the adjusting went.
You can see in your photo, the clevis isn't even in line with the push rod, it's bent up.
The push rod is usually tapped into the clevis for adjustments, the locknut just follows down and is nipped up once the settings are correct.
I wonder if you got the wrong master cylinder as that clevis looks very short.
Not much adjustment before the end of the push rod is hard against the pedal which will then jamb and cause the clevis to bend.
i wasnt even awarre the clevis was ment to be in line with the push rod, but every time i played with the stopper in the first picture, i had to re tighten the nut on the rod tin the 2nd picture too. Im just going to leave it like this, its got at least 6 months warranty anyway. Right now ive got alot of free play and the pedal feels soft now.
Edited by IM-32-FK
    • You're not wrong but 5W30 at 100C is like 10 cSt vs 25 cSt for 10W60. If we think in terms of viscosity margin 10W60 will probably still be ok at 130C but 5W30 is probably too little. It's absolutely shocking how hot the oil gets in something like a stock FL5 from only ~3 minutes of use on the Nordschleife. I would not risk taking a car like that to anything remotely intense without a ton of work done for cooling. Heat shielding on the manifold/turbo/downpipe, oil coolers, etc.
    • I think the concept is highlighting the various scenarios where thicker oil helps, and thicker oil potentially doesn't help and only generates heat and costs power, in turn for safety which isn't actually any safer (unless you're going real hot). If anything this does highlight why throwing Castrol 10w-60 for your track days is always a solid, safe bet.
    • Jason should have shown a real viscosity vs temp chart. All the grades have very little viscosity difference at full operating temperature.
    • Oops... I meant to include the connector  view... BR/W - power from fuse L/W - motor negative to fan control amp (and off to HVAC pin19) OR/B - PWM signal (from HVAC pin20) B --  ground
    • Yep, if you are applying filler it sounds like there is something wrong with the body lol. Safe to assume there is going to be a lot of sanding going on if your still applying fillers.  Picture a perfect bare metal panel, smooth as glass. You lay down your primer, it's perfect. (why are you going to sand it?) You lay down the colour and clear, it's perfect. No sanding at all took place and you've got a perfectly finished panel.  You won't be chasing your tail, sounds like you were prepping to start laying filler. If your happy with the body after the sanding, there is some bare metal exposed and some areas with primer, no issues at all, start laying the filler. You are safe to lay filler on bare metal or primer (of course check your technical data sheet as usual for what your filler is happy to adhere to).  This isn't a 100% correct statement. There is primer that is happy to adhere to smooth bare metal. There are fillers that are happy to adhere to smooth bare metal. Just make sure you're using the right materials for the job.  Typically if you are using filler, you would go primer, colour and clear. I've never seen any instances before where someone has laid colour over body filler (maybe this happens, but I haven't seen it before). So your plan sounds pretty normal to me.
