Build engine with standard rods and aftermarket Pistons if that's what you want to do. But be sure to abuse it (and video it) and post back with results(and videos) :)
+1 on video
can't wait to see the photo of this carnage, don't do a half ask job too. i want to see a massive hole in the block :)
I know of a car that ran about 400kw with standard rods for 10 years before they failed. When they failed the ripped in half. But it lasted a long time. I went with brand new rods on my build (nitto's) because they were cheap enough while the engine was apart.
+1 on video
What do you seriously think would cause that to happen with 450kw and prepped standard rods?
Age. It will eventually get any reciprocating part. Prepping standard rods buys you a certain amount of extra strength, and depending on how much effort is put into looking for cracks and so on, a certain amount of confidence that they are in good condition and not harbouring any cracks. But new cracks can form at any time once they've been up and down enough times.
The other killer is of course, rod bolts and the usual risks of being assembled incorrectly.
I have seen a few built blocks split their bore at not much more than 450kw, personally I would be keeping it as close to stock sized pistons as possible so as not to weaken the bore.
It's not pretty snapping or bending rods, I have been engulfed in the oil fueled fireball whilst standing beside the dyno, I would hate to see the carnage if it happened on the road at full noise for the sake of a relatively cheap set of rods, especially as you have the engine apart...
Why bother at all, just see what you can get out of the stock internals.
It was a late model 1UZ, light rods known to be undersized for the 1200nm of torque it was putting out. Ethanol was the culprit, along with the GT35 I fitted to it.
The RB26 block split was due to cylinder pressure I imagine, as was the Cossie Sierra race block that did the same thing. Tuning past that imaginary point where pressure beats steel. :P
  • Like 1
Ethanol produces more torque compared to petrol for similar power, especially when you lean on the boost past where the power stops rising. It is also nearly impossible to find the point where cylinder pressure rises exponentially due to it's anti detonation qualities. At some point some part will let go, where that is who knows, it comes down to your tuner at the end of the day.
If the 1UZ was on petrol, due to being high comp we would have had to stop boosting well before the point the rod went, with less timing. Revs were kept pretty much stock as I remember.
Just throw a stock rod under a 100lt press and record the pressure it starts to bend at, then do the same for an h beam/forged rod.
Bam...
Stock rod strength question answered!
15deg axial load, I'm going to say..... 3t
J.
Bam...
J.
Thats actually quite genius! anyone willing to donate a H beam? lol i got heaaap of spare rods
Guest
    • I don't like "actual computers" for in car use. They take time to boot up, have OS annoyances, and so on. Arduinos etc are ready to go a few seconds after power on, don't mind being agressively powere cycled, because everything is non-volatile, don't mind being shaken and stirred.
    • As Fred would tell us, it's all about interpreting the rules. It's not a water sprayer, it's a water mister... But everything else you've said, 100%! Even a raspberry Pi would be great, use HDMI out for a display, and add a raspberry Pi CANBus hat to read values out from the ECU.
    • Being a race car, and being in the era of the Arduino, one would think it would take little effort to build a controller to do the spraying based on a real physical measurment. Waaaaay back in the dim dark AS days, JE "designed" (as in, he had help) a microcontroller based intercooler spray system. It watched the difference between a temp sensor stuck on the core and one in the free air in front of the cooler, and if the temperature difference exceeded a (settable) threshold, it would activate the sprays. Thus, it only ran water when there was an actual need for water. If you stop to think about the actual physical things that are going on in that stack of coolers, there's probably at least a couple of triggering conditions one could come up with, and one could probably even run one pump with more than one solenoid valve, to allow water to be placed where it is needed, or at all points at once (if it is needed at all points). We're in the age of science baby. But.... I suspect that intercooler water sprays are on the forbidden list in most circuit classes, no? So only good for Targa type stuff?
    • I'll just leave this with, holy shit, those cars at work are awesome, and this will look wicked!
    • Could you modify this duct so instead it pushes the extra air through the radiator too and not down and out? For temps, I know it's not the greatest idea, but as a bit of a last resort, you could use a very intermittent misting spray onto the front of the coolers/rad. You don't want to be soaking them such that water is dripping off, but a small most on/off so that the water evaporates. That point of it constantly evaporating, rather than being soaked in water, will pull a LOT of heat out of the cooler. I'm literally thinking just the little mist sprayers for a garden from Bunnings. Being in a low humidity climate it will help even more! The other trick if you want to be ghetto is some shade cloth hung in the opening, and keep it wet. Pretty much now it's acting like an evap cooler on a house, but cooling the air you need to use to cool the radiator...   On a topic to think about too though, when air enters through the bumper, is it all nicely ducted from the edges of that opening back at a nice angle, or is it like most cars, and the edge of the opening just stops, and suddenly it's wayyy wider behind that? If it does the later, get it shrouded out at nice angles. When that opening changes too rapidly, it can actually cause a high pressure zone between the front bar and radiator, and limit air flow into that area, which means less air for cooling, as it effectively stalls the air, AND adds to drag...
