Used Trust Pe2 cat back R33 $300
MOMO 3inch exhaust $150
Nismo Pivot Ball $50
HKS GTRS RB26 turbo kit $1350
IMG_20170702_203941916.thumb.jpg.313f66631d74ccb4fa0f92cabd7029e1.jpgIMG_20170702_203949129.thumb.jpg.dfd975425d15284472f69b4665e62312.jpg
R33 RB25 Trust Oil Cooler and oil filter re-locator deluxe kit - Brand New Not fitted -$ 950
IMG_20170702_202133842.thumb.jpg.d2bbdb4699bc17eb6c20310964644ecf.jpgIMG_20170702_202151898.thumb.jpg.8f0965b37df4b3516439c0dcfb1970bc.jpg
R33 Alloy 52mm radiator used $100
R33 Hel Braided clutch line $80
R33 Series 1 GTR Gearbox good condition no transfer case $500
R33 GTST Metal intake plenum gasket - genuine Nissan only imageproxy.php?img=&key=4b1e78680f916b86  $80
R33 GTR GTS Hiflow Cat $100imageproxy.php?img=&key=4b1e78680f916b86
IMG_20170702_204500717.thumb.jpg.8da352bd4e2b2d232394af0f822ae154.jpgIMG_20170702_204452217.thumb.jpg.b48e6378abb33f72f3a31ef80c835b68.jpg
Suspension
R33 GTST Front and rear Sub frames, lower control arms with Brand new super pro bushes and ball joints, Rear Sub frame has whiteline polyurethane bushes all the control arms were sand blasted and powder coated black, also including whiteline diff bushes all new, Photos were after powder coating and before the ball joints and bushes were installed $1500
IMAG0248.thumb.jpg.7e53320a1c35aca199a16a3d2827814c.jpgIMAG0249.thumb.jpg.66c662920105ed8bdd6f1f9cf665b3d0.jpg
Hicas Elimination kit $150
Interior
Body
R33 GTST side skirts plastic White $150
Brakes
R33 GTST Brake Calipers F+R  $150 a set
ADR approved R33 Braided Brake Lines F+R - Used $100
Wheel
Work Ryver Wheels minor gutter rash all center caps included $500
IMG_20170702_205301842.thumb.jpg.50537cbb70e83f0f91287d795786bf75.jpgIMG_20170702_205330178.thumb.jpg.4a7fd49caca7cf11f405111e8506b31c.jpg
Contact: 040328133one
Note: Happy to post small items, larger items that contain oil wiimageproxy.php?img=&key=4b1e78680f916b86l need to be picked up in Canberra or i can deliver to syd for a small fee.
https://www.sau.com.au/forums/topic/454741-r33-gtstgtr-parts-sale/
no turbo setup?
sorry no turbo setup for sale, replied to all the pm guys.
thanks for the interest, if anyone needs a built motor talk to me!! it can come split up or ready to install and turn key if required.
PS: all the prices that are listed are high, but the more you buy and pick up the better deal i can work out for you and i can do lay-by on the big ticket items.
i also have 2 R33 shells as well if you needs parts
still got the greddy boost controller ?
sorry its on hold untill tomorrow night
Have I read that properly, R34 GTR front calipers and discs $400?
sorry you did, R34 GTR rotors will fit under the GTST calipers with the adapters i have for sale as well
  • 1 month later...
  • 1 month later...
  • 3 weeks later...
  • 2 months later...
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
