Used Trust Pe2 cat back R33 $300
MOMO 3inch exhaust $150
Nismo Pivot Ball $50
HKS GTRS RB26 turbo kit $1350
IMG_20170702_203941916.thumb.jpg.313f66631d74ccb4fa0f92cabd7029e1.jpgIMG_20170702_203949129.thumb.jpg.dfd975425d15284472f69b4665e62312.jpg
R33 RB25 Trust Oil Cooler and oil filter re-locator deluxe kit - Brand New Not fitted -$ 950
IMG_20170702_202133842.thumb.jpg.d2bbdb4699bc17eb6c20310964644ecf.jpgIMG_20170702_202151898.thumb.jpg.8f0965b37df4b3516439c0dcfb1970bc.jpg
R33 Alloy 52mm radiator used $100
R33 Hel Braided clutch line $80
R33 Series 1 GTR Gearbox good condition no transfer case $500
R33 GTST Metal intake plenum gasket - genuine Nissan only imageproxy.php?img=&key=4b1e78680f916b86  $80
R33 GTR GTS Hiflow Cat $100imageproxy.php?img=&key=4b1e78680f916b86
IMG_20170702_204500717.thumb.jpg.8da352bd4e2b2d232394af0f822ae154.jpgIMG_20170702_204452217.thumb.jpg.b48e6378abb33f72f3a31ef80c835b68.jpg
Suspension
R33 GTST Front and rear Sub frames, lower control arms with Brand new super pro bushes and ball joints, Rear Sub frame has whiteline polyurethane bushes all the control arms were sand blasted and powder coated black, also including whiteline diff bushes all new, Photos were after powder coating and before the ball joints and bushes were installed $1500
IMAG0248.thumb.jpg.7e53320a1c35aca199a16a3d2827814c.jpgIMAG0249.thumb.jpg.66c662920105ed8bdd6f1f9cf665b3d0.jpg
Hicas Elimination kit $150
Interior
Body
R33 GTST side skirts plastic White $150
Brakes
R33 GTST Brake Calipers F+R  $150 a set
ADR approved R33 Braided Brake Lines F+R - Used $100
Wheel
Work Ryver Wheels minor gutter rash all center caps included $500
IMG_20170702_205301842.thumb.jpg.50537cbb70e83f0f91287d795786bf75.jpgIMG_20170702_205330178.thumb.jpg.4a7fd49caca7cf11f405111e8506b31c.jpg
Contact: 040328133one
Note: Happy to post small items, larger items that contain oil wiimageproxy.php?img=&key=4b1e78680f916b86l need to be picked up in Canberra or i can deliver to syd for a small fee.
https://www.sau.com.au/forums/topic/454741-r33-gtstgtr-parts-sale/
no turbo setup?
sorry no turbo setup for sale, replied to all the pm guys.
thanks for the interest, if anyone needs a built motor talk to me!! it can come split up or ready to install and turn key if required.
PS: all the prices that are listed are high, but the more you buy and pick up the better deal i can work out for you and i can do lay-by on the big ticket items.
i also have 2 R33 shells as well if you needs parts
still got the greddy boost controller ?
sorry its on hold untill tomorrow night
Have I read that properly, R34 GTR front calipers and discs $400?
sorry you did, R34 GTR rotors will fit under the GTST calipers with the adapters i have for sale as well
  • 1 month later...
  • 1 month later...
  • 3 weeks later...
  • 2 months later...
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
