So... My V36 Skyline is soon to arrive to Australia, and I'm looking to change from the 20" aftermarket wheels currently on the car to a nice set of Matte Black wheels preferably available from Ozzy Tyres (online) and from the manufacturer XXR.
I'm looking for the best 'bang for value' \ value orientated set of wheels that look good, are relatively wide (and more flush, than tucked in appearance) and of course are legal - so I believe 18 x 8.75" on the fronts / rears are the way to go... unless someone suggests it's worth it to spend the extra $300 for the staggered rears setup (I believe they're 9.75" on the rears) :)
PS: Will 18's look too small on my V36 Skyline compared to 20's at the moment? Also, I won't be lowering the vehicle... Does anyone own a V36 Skyline *SEDAN* and have either of these wheels fitted?
Unless you can recommend another online (or local store in Adelaide) Ozzy Tyres seems to have the best range and value options with free shipping and guaranteed fitment.
What are your thoughts on the following wheels?
They're to go onto the following vehicle...
Any photos and information / help will be much appreciated!
Edited by Sikahalv
Cheap looking wheels look like a cheap suit , doesn't really matter which XXR rim you buy , you can't hide it .
Just buy some stockies again
Edited by NISSAN GTR
I have avant garde m310 which are very similar to the 530 you have listed went with 20s in the staggered option got 8.5" +30 in the front and 10" +40 in the rear painted in dolphin grey from ozzy tyres, tyre wise 245/35 fr and 275/30 rear. Go staggered the extra width allows a much better launch, reducing wheel spin considerably....
if I had my time again would go a less aggressive offset in the rear maybe +45 and get a 285/30 tyre in there which would have almost identical rolling diameters front to back and slightly more sidewall.
As for ozzy tyres, good luck. First set they sent me was drilled in the wrong stud pattern second, second set the painter hadn't applied a primer and now the paints flaking... Just waiting for a time where I can get them powder coated.
Will the Forged Ray's 19" Wheels from a V35 be a straight bolt-on without needing spacers?
How will the offset look? Tucked in or near flush?
I have those on my friends V36 coupe at the moment which has same offsets as a sedan. They sit near flush compared to the OEM wheels these cars come with.
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
