How we all doing?
Has anyone managed to get performance bracing on a NA Skyline? It doesn't even come with a rear sway bar.
I have a Apexi N1 Evolution Cat Back Exhaust with a 3.5 inch pipe and a 4.5 inch tip so will fitting be an issue?
Thanks for the help guys, just shout if I missed any details.
https://www.sau.com.au/forums/topic/454767-na-r34-skyline-performance-bracing/
No rear sway bar? I find that hard to believe...!
It's true! I thought it may have been removed by the original owner, or the japanese owner, however it's true, there are a few threads about it, however they never really confirmed a kit.
3.5" on an NA, thats a bad idea!
I didn't put it on! But no plans on removing
Firstly, we'll deal with my pet peeve. There's no such thing as a "sway bar". At least not in the context of a car not pulling a trailer. They are anti-roll bars.
Second, ARBs are not "performance bracing". They are just suspension components. NA Skylines are not performance cars. They were sold to Japanese who wanted a RWD Camry and drove them around like RWD Camrys. If you want to "tune" it, go right ahead. Nearly everything you can do to a turbo car you can do to an NA, including fitting a rear ARB. The bolt holes should at least be present in the floor. You just need the bar and the brackets.
"Performance bracing" on Skylines, if by that you mean strut tower braces and the like, are an almost total waste of time. As are most of the other bits of metal you can strap onto the car in various weird and wonderful places. Sure, they all do "something", but almost no-one really needs them. Especially on an NA car.
And I have to concur with 75coupe. Big exhausts on small NA 6s sound like arse crust.
According to Wikipedia they're the exact same thing.
Okay you don't like the car, cool, but is it really necessary to attack someone else's car? You didn't even answer my question.
Sorry, I would have bought a GTR if I could have but I'm just trying to work with what I've got and have some fun with my mates doing it, not trying to break any land speed records or set record times at the nurburgring. If this was about speed and performance I'd just take it to a shop and pay for it.
To each his own I guess.
Edited by 00RORY
But is he referring to the sway bay "anti roll bar" or just saying he doesnt have a rear strut tower brace in the boot???
Because without the rear sway it would have very noticeably bad cornering
3.5" exhaust on na would not just sound bad its simply not needed, and would do more bad than good on na...
the term 'sway bar' is perfectly acceptable and I've yet to see anyone confused as to what the term refers to when discussing car related matters. Its name is also accurate, with its function to influence & control the sway/roll of the vee-hickle, as per dictionary definition of sway " To incline or bend to one side;".
Anyway yes you should get one if you don't have one and yes you have a right to be proud of your car but you should keep in mind if you're serious about moving to performance driving you should consider moving onto other options rather than spending a lot on an n/a car which is unlikely to deliver the overall performance result you're after without spending bank-heist loads of cash on it.
Oh, there's nothing wrong at all with perpetuating the use of the incorrect terms for things. Nothing at all. Progressively dumbing down the population is a laudable aim. Go for it.
Sway, by the way, means a side to side motion MUCH more than it means a motion in rotation about an axis, which is what body roll really is. Just try asking a suspension engineer at a race team to calculate the location of the sway axis on his car.
How we all doing?
fit the swaybar mate, should help definitely. also look into some cheap but decent coilovers like BC. the cars not going to go particularly fast but you can make it handle very well and when driven properly, still embarrass people in the twisty bits.
good on you for looking properly into the handling of the car. your starting in the right place for modding.
i agree with most people, that exhaust is designed for a turbo engine where the turbo is dampening allot of the noise from the engine and the huge diameter is *atleast could possibly be* needed for the exhaust flow. on an NA is is grossly oversized.
the noise may be to your liking and in that case, cool, but i dare say after a while the drone, bark/farting, and general awfull noises will do your head in. i suggest have a listen to some better options and make a more informed decision. that being said, when i was a p,plater i made all the same usual bad choices :)
but hang on there G-Money, you're getting confused again with 'your opinion' being the 'correct term' and only possible option. Another equally correct (and for the purposes of sh*tstirring I will say 'more correct') term is 'stabilizer bar'. WHY aren't you calling it by its CORRECT name of stabilizer bar??
Also Vanilla Ice, ever seen a tree swaying in the wind? the upper branches sway in an arc from a lower roll centre, the whole tree doesn't evenly move side to side as one unit.
So you see MC Hammer, it's a petty point that only pedantic mofo's would bother making a deal about, and you've once again made me waste 5 minutes of my lunch break pointing this out.
Although if you would like to tell me how you feel about coilovers I am all ears.
PS Funkmaster Flex I give you full credit for having a fair amount of knowledge about car related stuff as I have said before, and am doing nothing more than trying to get you to not take it so serious, what's it matter if it's called sway bar, not like he's called it a hulahoop rod.
By all means fit a set of Stage II suspension components if you are so inclined but remember it all starts with a set of quality tyres, correctly inflated....and read Gary's thread above labelled "shockabsorber 101"
    • The exhaust gases are at their highest temperature as they leave the exhaust port and enter the manifold. They cool as they flow through the manifold because they transfer heat to the manifold and the manifold loses heat to the surrounding environment. Thus, inevitably, the exhaust gases are cooler as they enter the turbo compared to when they entered the exhaust manifold. So, yes, the exhaust manifold can easily get as hot as the turbine housing. Having said that, you will generally see the highest temperatures where the exhaust gases have to slow down or they are concentrated into one area - which is usually the collector on the manifold and in the turbine housing, because the gases slam into the metal at those places, increasing the convective heat transfer coefficient and transferring even more heat to the metal than they might just flowing past elsewhere. Exhaust manifold heat shields are a good idea - certainly for the stock manifold they are there from the factory. People seldom have anything like that on a tubular manifold because they are hard to achieve. Some might wrap a tube manifold with fibreglass tape - but this has a reputation of leading to cracked welds. The best case is generally to put ceramic coating onto the manifold to prevent it getting as hot (internal coating) and radiating/convecting heat into the bay (external coating). All the real heat from a turbo comes from the exhaust side. The gases entering are at ~800-900°C and the steel/iron gets nearly that hot. The compressor side is only going to heat the charge air up to <<200°C (typically not much more than 100°C). So that's nothing, by comparison. The compressor is not a significant source of engine bay heat.
    • Late to the party, specifically joined this forum as I just bought one of these and this thread has been a gold mine of info. If the OP is still around, mind if I ask what gas you been putting in yours? Mine has a Japanese sticker in the cap saying premium but it seems to get way worse mileage on premium (95) than 91. I always thought it was meant to be the other way round🤷 I do think Nissans claimed "6l/100km" is a bit fantastical 😂
    • Does exhaust manifold get hot as turno exhuast side? I have a turbo cover to managr heat in the engine bay but  nothing is covering the exhaust manifold before turbo   i know as turbo does compress air, the temp does go up however does that mean exhaust manifold would be as hot?
    • It's excellent but I'm still breaking it in so I'm not 100% sure where it'll end up. I would say it's about 15% heavier than stock and the smoothness of the slip zone is quite progressive but you need to be a little patient compared to stock or it'll bite hard and stall. Stock I got away with absolutely horrid clutch control. Like I said before I couldn't even tell where the clutch would grab when it was stock so releasing way too quickly without enough revs it would just slip and the revs would drop lower than ideal but that would be the end of it. Currently there's a bit of a nasty clutch judder if I don't apply enough revs + find the exact wrong point of the slip point in the clutch pedal but it feels like it's slowly resolving as I drive it more. I would not recommend the competition clutch unless you really need the extra clamp force. I think this clutch combined with the Nismo operating cylinder is going to be exactly what I want. Enough bite that you need to remember the release point to avoid stalling or rough shifts, but progressive enough that it's not hard to drive by any means and not heavy at all. I tried a "super single" clutch on my friend's 997.2 Turbo 6MT and that was absolutely horrid. It runs an electrohydraulic power steering pump for the clutch power boost so there's zero feedback in the clutch pedal and there was a horrific clutch shudder well after break-in due to the lack of marcel springs or hub springs in the friction disk. It felt like the slip zone was the thickness of a single toe twitch as well so it was almost impossible to avoid stalling it unless you gave it a ton of revs and just dumped the clutch instead of trying to be smooth with it. I was terrified of pulling out in front of traffic. I have also tried some kind of "super single" on an EK9 and that makes this twin plate Coppermix look like a stock clutch. Releasing the clutch pedal even slightly too quickly feels like you're getting rear-ended. The pedal is extremely heavy as well and there's no vacuum assist like the GTR.
    • Yeah, well I was probably way underguessing the $300 figure anyway. Just multiplied a "normal" by 4 for the purposes of pointing out it's not cheap, particularly if it has to be repeated.
