You want a union or just the threaded part for the oil sandwich? If the latter try Nissan or otherwise.
http://www.powerflowperformance.com.au/tees-elbows-unions-swivels-unions-male-flare-union-c-143_179_183.html
Edited by djr81
RB30. You can even try Holden and see if they will sell you one.
Someone did have the part nunber listed in a thread some time ago but cant help you with what thread it was
That thread may still be salvagable if you want to find the right dye for it. I pulled my stud off an RB30 at the wreckers and ended up having to use vise-grips and damaged the thread a bit. Cleaned up alright though. Running in the car at the moment
Thanks mate,
I ran a Die over it yesterday and it was pretty bad still. considering i need to screw it in to pretty much the end of its thread to get the oil block to sit tight, Id rather just get a new one for the sake of a few bucks
I just got off the phone with Andrew at Kudos motorsport and he is going to supply the stud and a suitable filter with a pressure releif valve.
Btw the part number your talking about is 15213-21001
Haha thanks Ravi
A point to note:
I've read through many other threads on this without clear indicators on what you need to do to make this work with a greddy oil block.
If you remove the heat trasnfer block You can use a standard rb26 filter if you knock a pressure relief into the block where the return is
Then just use the RB 30 filter stud.. Here's the part numbers
All up costs $50 from kudos.. That included 2 genuine oil filters
I highly recommended them, Andrew and Ian are top guys and are always willing to help
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
