Want To Make R33 Gts-t Louder
muzziak
 Share
Hey guys, have a R33 GTS-T series 2 with the following mods and want to make it louder ;
-fmic
-cold air intake
-splitfire coil packs
-kls power spirit turbo
-full turbo back exhaust
-apexi power fc
-walbro fuel pump
-high flow cat
-dump pipe, bov etc.
All the little necessities really.
Want to make it louder, was wondering what I could do to make it louder, buying a new exhaust being the obvious answer(what type). Attached is a pic of my current exhaust, thanks.
one pipe from the turbo to the rear muffler? Unlikely even if it is a full custom job
They can just chop off your rear muffler and fit a cannon. That will do what you want.
Can't believe I just told someone to fit a cannon
  • Like 4
I love the way this OP thinks. Metal intake pipe helps with loud induction noise. I have a worn out Blitz nur spec exhaust, frequently get told 'why is your car so loud" and alot of dirty looks, alot of approving looks too cause it sounds sweeeeet and is straight thru. Would recommend.
A metal turbo inlet consists of 1 or 2 mandrel bends, some straight pipe in 1 or 2 sizes, maybe a conical reducer, and a couple of stubs of smaller pipe sticking off of it. Some welding rod/mig wire, flapper discs, paint, rubber joiners and hose clamps usually complete the picture. Oh and a chop saw or similar way to trim the bits to size and shape. Oh and a drill. And maybe a die grinder. Actually, all this is starting to sound a little complicated if you don't have all that stuff. But most performance workshops who fit/upgrade turbos have it. Throw the job at one.
 Share
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
