Hi guys!
I hope you are doing well ;]
Just found an interesting article when I was doing some reading on a Japanese discussion forum (2ch) about Skyline Coupe V35.
Some guy posted a link where a journalist took some pictures of one of the first test car of the R35 GTR in one of Nissan's service centre in Japan.
The car is pretty much a GTR, but with the looks of the CPV35. Some of the parts on the concept car such as the brakes, exhaust and sound system was used in the
finalised version of the GTR.
I wish Nissan produced a slightly tuned up version of the CPV35 and make a "female" (one of the designer of the GTR described it as a muscular male) version of the GTR! haha
Source of the pics (sorry in Japanese):
http://car.watch.impress.co.jp/docs/news/20130205_585419.html
"Female" GTR haha
Air duct on the bonnet to cool down the turbo system.
Exhaust and diffuser pretty hot!
Side fender a bit wider.
Front brakes with 6 piston caliper also used on the final version of the GTR.
Rear brakes with 4 piston caliper also used on the final version of the GTR.
Inside the engine bay is pretty similar to the GTR.
Sound system and sub woofer like in the GTR.
  • Like 1
https://www.sau.com.au/forums/topic/454855-cpv35-gtr-version/
The steering wheel on the left I don't know... Just used a G35 that they got from Germany to test in the Nurburgring? Not sure..
This is not the concept car but the test car even before then made the concept car. I assume Nissan developed the Premium Midship Platform from these testing with the CPV35 and created the concept car that they launched. Just speculation sorry..
Didn't they use the V35 body during testing of the R35 drive train? Because the R35 body was still being built/tweaked?. So this was probably just one of their 'test' builds. It was never going to be a production build.
According the the article on the link, this test car is using the same/similar AWD system as in the GTR.
And yes, this was just going to be a test car before they finalised making the body of the GTR so they never planned to make a
GTR version of the CPV35. After they were done with the body design of the GTR, Nissan started developing it on the Nurburgring and pretty much never touched this CPV35-GTR test car again.
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
