For those who are interested, I ended up posting a more concise version of this whole ordeal here: http://www.jdmr32.com/hicas-aftermarket-steering-wheel-error-light/
  • 2 years later...
Hi Skyliner's ...
I have a question, maybe you can help me out here... ?
I used to be A authorised Nissan workshop and had Fast at the time, but I cant seem to get fast working with Win. 10. Also we are located in Denmark so we have the european disc for Fast. Anyway...
I have this R32 / chassis nr: BNR32-013497 from 12/1990 , an "early" model.
It is imported from Malaysia, and came with a nissan GTR steering wheel - I noticed when driving for some time 20 minutes or so, that the steering jumped - no Hicas light came on - but the rear wheel turned slightly when it was supposed to be straight.
checked the Hicas with a Nissan Consult II tester - No faults but read 153 degres to the left on steering angel sensor when the steering wheel was straight,
I took the steering wheel off, and yes it was the new type with the holes at 12 & 6.
when I lign the steering angel sensor up with the middle point of the neutral signal it of course lines up at 1 & 6 o'clock.
So I have the "early" type of steering angel sensor and the new type steering wheel...
I have looked at some parts catalog pages, and seemed to have found that the early steering angel sensor should
be part number: 28475-01U00 or alternative number: B8475-01U00. (there are no number readable on the sensor equipped)
The Question is I think I have found the later version of steering angel sensor equipped from 09/1991 -  models
wich should have the number 28475-01U11 or alternative number:  B8475-01U11.
Do you know if this number are for an sensor with alignment 12/6 o'clock and does it fit on the car with the early version´s ?
Cause Nissan europe cant confirm this for me.
If I could buy the new type sensor that fits the steering wheel, then I can get the Hicas working with the steering wheel at the right position, right now I drive around with the steering wheel turned 153 degrees and the Hicas works superb.
Hope you have the answer for this - best regards Lars.
