Hey!
My HID headlights have started to randomly turn off while driving.
It will usually flicker on/off for a second before staying off. They turn straight back on again after turning the lights on and off, but will start doing it again shortly after. Its not both lights in unison either. One goes... then the other.
It appears to be triggered by G-forces/movement as it often flicks off when i make a sharp turn or go over minor bumps in the road.
Anyone know what could be causing this or of a good auto-electrician in the Brisbane area?
I can't find anything on the forums except someone in Sydney with the same issue on a V35 that had zero responses.
Thanks in advance for any help!
Sounds like it's the lamps. Have you tried another lamp? Turning it off and back on makes the ballast kickstart the lamp with an initial high voltage discharge. It's more likely your lamps would both go out so close together rather than your ballasts.
Replace the lamps.
Make sure you get colour matched ones
I had the same issue with my Stagea running Xennons, and they would both go out when driving at night. Fixed by replacing the old ones with new ones.
I guess we don't know how it is. :yucky:
Actually, while it's fresh in my mind, not that I need to buy any now but I'm a little disappointed with the high beam performance of these headlights. Even my BA lights up a street better with its high beams. I suppose that's more of a limitation of the headlight mechanism but as far as squeezing the most performance out of the lamps themselves, which ones do you recommend Chris?
Edited by The Max
I have seen LED lights in these. dont seem to be that bad.
HID bulbs pulse when they need to be replaced. They often don't "burn out" perse, but the chemical reaction inside the bulb reaches its limit, and needs to turn off to rewind the process. Replace bulb, It will be fine. Note: don't touch bulb with fingers, or it will go pop.
What high beam halogens? I thought the headlight mechanism just repositions the HID bulbs up a little higher? Hence my question. I'm seeking the best performing bulb for the job.
Ahh the G37/V36 are bi-xenon. The cutoff shield drops when you high beam.
Look at the link I sent you, there are some 'higher output' bulbs but they cost a pretty penny. I think you'll be happy with the Philips Xtreme (since it's closer to 5000K than the Osram Night Breakers).
Yes, good quality (genuine) bulbs are expensive. I've been through $150+ worth of ebay xenon bulbs and can tell you to go genuine from the get go.
One seller sent me 3 4300K bulbs, all different shades of white/yellow. What a waste of money!
To add, switching from ebay to Genuine Philips D2S gave a very noticeable improvement in light (colour, brightness, more evenly spread beam). Same projector/headlight.
That's why I'm advising to go genuine, I've already been though the shit so you don't have to!
Exactly why I asked. :)
I can't remember what my V36 came with off the boat but I'm fairly certain they were Osram bulbs. Anyway, when the time comes, I'll seek out the Philips ones.
I replaced the D2S bulbs in my 5GEN Liberty last night (have to get to the headlight via wheel well, shitty clips makes life difficult). Lights were so dim I couldn't see at night, the driving lights were brighter (country car so assuming lights were on all the time).
Chucked those Philips D2S replacement bulbs in = can see now.
So which ones of the bulbs did u buy? my stock ones on the v36 are not bright enough imo...
I thought he mentioned that in the last line of his last post?
uumm yeah he mentioned its philips but that brand has more than one type of bulb...just wanna know which has most output so i can spend my money wisely... :)
See his post in #12 above. Philips Xtreme.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
