V36 Hid Headlights Flicking Off / Good Auto-electrician In Brisbane?
Hey!
My HID headlights have started to randomly turn off while driving.
It will usually flicker on/off for a second before staying off. They turn straight back on again after turning the lights on and off, but will start doing it again shortly after. Its not both lights in unison either. One goes... then the other.
It appears to be triggered by G-forces/movement as it often flicks off when i make a sharp turn or go over minor bumps in the road.
Anyone know what could be causing this or of a good auto-electrician in the Brisbane area?
I can't find anything on the forums except someone in Sydney with the same issue on a V35 that had zero responses.
Thanks in advance for any help!
Sounds like it's the lamps. Have you tried another lamp? Turning it off and back on makes the ballast kickstart the lamp with an initial high voltage discharge. It's more likely your lamps would both go out so close together rather than your ballasts.
Replace the lamps.
Make sure you get colour matched ones
I had the same issue with my Stagea running Xennons, and they would both go out when driving at night. Fixed by replacing the old ones with new ones.
I guess we don't know how it is. :yucky:
Actually, while it's fresh in my mind, not that I need to buy any now but I'm a little disappointed with the high beam performance of these headlights. Even my BA lights up a street better with its high beams. I suppose that's more of a limitation of the headlight mechanism but as far as squeezing the most performance out of the lamps themselves, which ones do you recommend Chris?
Edited by The Max
I have seen LED lights in these. dont seem to be that bad.
HID bulbs pulse when they need to be replaced. They often don't "burn out" perse, but the chemical reaction inside the bulb reaches its limit, and needs to turn off to rewind the process. Replace bulb, It will be fine. Note: don't touch bulb with fingers, or it will go pop.
What high beam halogens? I thought the headlight mechanism just repositions the HID bulbs up a little higher? Hence my question. I'm seeking the best performing bulb for the job.
Ahh the G37/V36 are bi-xenon. The cutoff shield drops when you high beam.
Look at the link I sent you, there are some 'higher output' bulbs but they cost a pretty penny. I think you'll be happy with the Philips Xtreme (since it's closer to 5000K than the Osram Night Breakers).
Yes, good quality (genuine) bulbs are expensive. I've been through $150+ worth of ebay xenon bulbs and can tell you to go genuine from the get go.
One seller sent me 3 4300K bulbs, all different shades of white/yellow. What a waste of money!
To add, switching from ebay to Genuine Philips D2S gave a very noticeable improvement in light (colour, brightness, more evenly spread beam). Same projector/headlight.
That's why I'm advising to go genuine, I've already been though the shit so you don't have to!
Exactly why I asked. :)
I can't remember what my V36 came with off the boat but I'm fairly certain they were Osram bulbs. Anyway, when the time comes, I'll seek out the Philips ones.
I replaced the D2S bulbs in my 5GEN Liberty last night (have to get to the headlight via wheel well, shitty clips makes life difficult). Lights were so dim I couldn't see at night, the driving lights were brighter (country car so assuming lights were on all the time).
Chucked those Philips D2S replacement bulbs in = can see now.
So which ones of the bulbs did u buy? my stock ones on the v36 are not bright enough imo...
I thought he mentioned that in the last line of his last post?
uumm yeah he mentioned its philips but that brand has more than one type of bulb...just wanna know which has most output so i can spend my money wisely... :)
See his post in #12 above. Philips Xtreme.
 Share
    • The two diagrams are equivalent. The R32 one is just one sheet out of about 3 showing everything in the whole car all at once. And without knowing the functionality that occurs in the modules, they are both equally opaque.
    • 8v - 2.48ms 9v - 2.15ms 10v - 1.74ms 11v - 1.41ms 12v - 1.15ms 13v - 0.99ms 14v - 0.89ms 15v - 0.82ms 16v - 0.81ms I'm running these values on my RB20 Neo with 570cc Denso R35 stock jets and it's great. Also bought a set for my Legnum VR4, love these injectors!
    • Thanks for your reply,  Those blue/green wires running to the actuator aren't attached to anything, so I'm not sure how the central locking is still working. I will have to take a good look tomorrow, I don't have the car with me. After googling it seems like a pretty common aftermarket actuator which even uses the same green/blue wires the immobiliser required. i'll test everything tomorrow and if it's working i'll melt the solder, strip it, resolder and neaten it all up with some heat shrink. I don't have to understand it if it works hahaha I just don't want a fire/ short circuit. That R32 diagram looks more like a continuity chart? Can you make sense of this form the R34 manual? 10V is probably due to very flat battery, i'll recheck as well tomorrow, I did have to jump start it haha. Thanks again!
    • So, COM doesn't mean comms. It means common. What common itself means will depend on the type of device. For a two directional actuator (ie, one that can push and pull on the same output rod) then the common will typically just be the earth connection. There will be at least 2 other wires. If you put 12V on one of the other wires, then the actuator will push. On the other 12V wire, it will pull. Can't quite make out what is going on with the wiring of your actuator. It appears to have several wires at the actuator plug, but there only appears to be 2 wires where its loom approaches the door control module, with at least one of the others cut off. I don't know these actuators off by heart. I'd have to look at a wiring diagram for one before knowing what the wires were about, and that's despite me having to replace one in my car not all that long ago. Just not interesting enough to have dedicated memory set aside for trivia like that any more. That actuator is an aftermarket one, not the original one, which probably died and was replaced. That might require some sort of bodge job on wiring to make it work. Although nothing should justify the bodginess of the bodge job done. As to the soldering job on the door module's loom plug. Ahhahhahaha. Yes, very nasty. Again, I cant tell you what any of those wires do. You'd need to study the R34 wiring diagram (if you can find one that shows the door module). I don't think I have any. I'd have to study the R32 diagram to start to understand what mine is doing, and again, even though I've had a problem with mine for the last 25 years (where it locks the passenger door when the driver's window reaches top or bottom of travel) I'm just not interested enough to try to to work it out. So long as it's not burning down, it's fine with me. Here's the R32 GTR diagram, which, confusingly, has rear door lock actuators and window motors on it!! As you can see, unless you understand the functions of the door lock timer and the power window amplifier, you'll never be able to work out how it works just from the diagram. I don't imagine that the R34 one is any better. Hopefully an R34 aware bod can help. FWIW, the two wires that are cut and joined look like they are both power supply - so hopefully it is not fatal to join them. The 10V you measured on the cut off free end of one of them is concerning. You'd expect 12V, and it might be the reason for the bodge job joining them together.
