Hybrid intercooler kit Chrome plating coming off pipes
Guest darrinspencer
I have Hybrid FMIC kit on my 33gtst
I purchased last November thru the group buy on this site.
The chrome plating on the alloy pipework each side of the intercooler is bubbling and starting to come off.
Rang Powerdigger (Hybrid) in Sydney with not much help from them. Even though
the kit was directly mailed from them to me, their not real keen on any warranty.
Has anyone esle had this same problem?
Get a few people together and go back to them.
Other than that, get quotes from some places to fix the faulty work, and take that to them.
They will then fix the faulty work themselves, if they don't, take those quotes to the CCC (Consumer commission)
BASS OUT
I have the same problem. The chrome plating was starting to bubble up not one week after the piping was fitted. This will always be a problem even if they did get it re-chromed or gave you some new piping as the chrome plating will never bond firmly with the aluminium pipework.
Guest darrinspencer
Anodizing is Uber-cheap.
Shouldn't cost you more than $20 for the whole lot.
It will most probably be the minimum charge for the place that you go to.
Anodising is cheap to do, but it is only as good as the finish to start with, so the pipes will need to be polished first.
yeah wots the go with the 33 kits? I've got a hybrid kit on my 180 and its got cast pipes and their polished ... yeah cast is heavier and the heat properties are different but if they go to the effort to polish the cast why not jus polish the whole kit? would be cheaper than chroming wouldn't you think?
Darrin if you get them polished you can clear anodise them then they will never stain or go dull and its pretty cheap..... chrome by its properties never adheres to alloy that fantastic so im not suprised if they are alloy like you are all saying that this is happening.... plus it is probably crap chrome and crap preperation again if you wanted a really good chrome job on your pipes you would be paying 400-500 just for the chroming, so you are getting what you paid for.... a $100 chrome will be sh!t, and not last.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
