Hybrid intercooler kit Chrome plating coming off pipes
Guest darrinspencer
I have Hybrid FMIC kit on my 33gtst
I purchased last November thru the group buy on this site.
The chrome plating on the alloy pipework each side of the intercooler is bubbling and starting to come off.
Rang Powerdigger (Hybrid) in Sydney with not much help from them. Even though
the kit was directly mailed from them to me, their not real keen on any warranty.
Has anyone esle had this same problem?
Get a few people together and go back to them.
Other than that, get quotes from some places to fix the faulty work, and take that to them.
They will then fix the faulty work themselves, if they don't, take those quotes to the CCC (Consumer commission)
BASS OUT
I have the same problem. The chrome plating was starting to bubble up not one week after the piping was fitted. This will always be a problem even if they did get it re-chromed or gave you some new piping as the chrome plating will never bond firmly with the aluminium pipework.
Guest darrinspencer
Anodizing is Uber-cheap.
Shouldn't cost you more than $20 for the whole lot.
It will most probably be the minimum charge for the place that you go to.
Anodising is cheap to do, but it is only as good as the finish to start with, so the pipes will need to be polished first.
yeah wots the go with the 33 kits? I've got a hybrid kit on my 180 and its got cast pipes and their polished ... yeah cast is heavier and the heat properties are different but if they go to the effort to polish the cast why not jus polish the whole kit? would be cheaper than chroming wouldn't you think?
Darrin if you get them polished you can clear anodise them then they will never stain or go dull and its pretty cheap..... chrome by its properties never adheres to alloy that fantastic so im not suprised if they are alloy like you are all saying that this is happening.... plus it is probably crap chrome and crap preperation again if you wanted a really good chrome job on your pipes you would be paying 400-500 just for the chroming, so you are getting what you paid for.... a $100 chrome will be sh!t, and not last.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
