Hybrid intercooler kit Chrome plating coming off pipes
im so mad with my cooler kit rite now..
got a hybrid one for an r34 gt-t thru that damn group buy ages ago
just started installing it thise weekend
so far i have been working on r33 instructions that they gave me which is quite different
had to make my own brakets as theirs do not fit!
been working on it for 2 full days straight and now i cant get the bonnet to closed as they still hit fan blades even tho ive cut them enuf already
oh and not to mention asked for red silcone back then and got red and they was told they had no blue left so.....
not happy
what should i do!?
this thing is f**king my car up
Power digger actually have an R34 there that they are sponsoring and the cooler they put on it fit nicely.
Plates are ONFILE its a yellow R34 GTT.
It seems that there is alot of mixed reaction and fortune with these kits.
All the kits ive had personal experience with went it with only the slightest modification and they havn't had any problems at all.
Maybe its just luck of the draw.
Yeah i had a fun experience with mine as well Driver, 5 hours my ass... I've had mine on for about 2 months now and the piping is already starting to bubble, its not fazing me that much not to concerned with the look as long as its doing its job!! The thing i was most peeved about was there was no return for the standard boost solenoid in the in let manifold and when i rang powerdigger they just said yeah you'll have to that yourself. I did take the opportunity to remind him that this was a "kit" custom built for R33's so.... That got me no where so out came the drill.
Works good now thou so can't complain really. And had a Link ECU installed the other day and the dyno tuner and i where both impressed with the combined packages result so all well that ends well... for the time being.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
    • Was that Australia Delivered Duncan? Does it have siren etc?   I used to have remote start on an old 32 two decades ago, it was a cool feature. I used to wake up early in winter for work. Start it and by the time i was out the door a few minutes later the engine was warmed up and the heaters had the car toasty. It was great.    I don’t mine the ambience lighting.  I drive a western star and it has footwell lights and ambient lighting and it’s great! From the pics of seen of them installed in a skyline I think it’s a nice touch
